Up to 20% off select tools
Samsung Gear Live Back Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
4
Past 7 Days:
15
Past 30 Days:
95
All Time:
2,425
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 minute
Difficulty: Easy
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Tools
Introduction
Go to step 1 ↓
This guide is used only as a precursor to the battery, vibrator motor, and heart rate monitor removal and replacement.
    1. Samsung Gear Live Back Replacement, Lay the watch face-down: step 1, image 1 of 1
      • Lay the watch face-down on a flat, stable surface.
      Ask FixBot
    2. Samsung Gear Live Back Replacement, Remove the holding pin: step 2, image 1 of 1
      • Press the watchband down against the work surface.
      • Press the tip of a flathead screwdriver against the edge of the spring-loaded holding pin.
      Ask FixBot
    3. Samsung Gear Live Back Replacement, Remove the watchband: step 3, image 1 of 1
      • With the spring-loaded pin pressed in, the watch band should release easily.
      • Gently pull the band away from the body of the watch.
      • Repeat steps 2 and 3 for the opposite side.
      Ask FixBot
    1. Samsung Gear Live Back Replacement, Locate the four screws: step 4, image 1 of 1
      • With the watch laying face-down, locate the four screws. They are located on the back of the watch, at the four corners.
      Ask FixBot
    2. Samsung Gear Live Back Replacement, Remove the 4 screws: step 5, image 1 of 1
      • Using a Torx-T5 screwdriver, remove each of the four 4mm screws and set them aside.
      Ask FixBot
    3. Samsung Gear Live Back Replacement, Pry off the back of the watch.: step 6, image 1 of 1
      • Gently work the plastic opening tool under the top edge of the watch’s back cover.
      Ask FixBot
    4. Samsung Gear Live Back Replacement, Lift off the back cover: step 7, image 1 of 2 Samsung Gear Live Back Replacement, Lift off the back cover: step 7, image 2 of 2
      • With the watch’s back cover pried loose, gently lift it away from the front half of the watch.
      Ask FixBot
    5. Samsung Gear Live Back Replacement, Set both halves of the watch aside: step 8, image 1 of 1
      • Lay both halves of the watch body assembly face down (with internal components facing up).
      Ask FixBot
Author
with
Keith Cooper
1,265 Reputation
6 Guides authored
USF Tampa, Team 1-7, Brown Fall 2014 Member of USF Tampa, Team 1-7, Brown Fall 2014
USFT-BROWN-F14S1G7
3 Members
72 Guides authored
1 Guide Comment
Mention the screwdriver in the tools needed section.
Dan Brown - Reply Share
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 95
All Time: 2,425
