Up to 20% off select tools
Samsung Gear Fit Screen Replacement
Views: 55K
View statistics:
Past 24 Hours:
4
Past 7 Days:
17
Past 30 Days:
108
All Time:
55,033
Comments: 29
1 comment on steps, 28 guide comments.
Go to guide comments
Completed: 17
17 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Easy
Tools
    1. Samsung Gear Fit Screen Replacement, Watch Band: step 1, image 1 of 2 Samsung Gear Fit Screen Replacement, Watch Band: step 1, image 2 of 2
      • Place your thumbs on the ends of the screen.
      • Push the watch outward while pulling the band away from the watch.
      Ask FixBot
    1. Samsung Gear Fit Screen Replacement, Screen: step 2, image 1 of 1
      • Heating the device with a hair dryer may warp the screen or damage the device. It it preferable to use an iOpener for this step.
      • For step-by-step instructions on using an iOpener, see the iOpener Instructions.
      • Use a hair dryer, heat gun, or an iOpener to heat the Gear Fit for 1-2 minutes until it is hot to the touch.
      Ask FixBot
    2. Samsung Gear Fit Screen Replacement: step 3, image 1 of 3 Samsung Gear Fit Screen Replacement: step 3, image 2 of 3 Samsung Gear Fit Screen Replacement: step 3, image 3 of 3
      • The screen is connected to the device by a ribbon cable on the left side with the power button facing you. Do not try to completely separate the screen from the device yet, and be careful.
      • Gently pry the screen loose using a plastic opening tool.
      • If the screen doesn't easily come loose, more heating may be required
      Ask FixBot
    3. Samsung Gear Fit Screen Replacement: step 4, image 1 of 3 Samsung Gear Fit Screen Replacement: step 4, image 2 of 3 Samsung Gear Fit Screen Replacement: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Using tweezers as a lever, pry the inner assembly out of the external casing.
      • This will be harder than removing the screen. Moderate force may be required.
      Ask FixBot
    4. Samsung Gear Fit Screen Replacement: step 5, image 1 of 3 Samsung Gear Fit Screen Replacement: step 5, image 2 of 3 Samsung Gear Fit Screen Replacement: step 5, image 3 of 3
      • Disconnect the ribbon cables connecting the screen to the motherboard by lifting their metal connectors up off of the board with tweezers.
      Ask FixBot
    5. Samsung Gear Fit Screen Replacement: step 6, image 1 of 2 Samsung Gear Fit Screen Replacement: step 6, image 2 of 2
      • Gently peel the screen assembly up and away from the device using tweezers.
      Ask FixBot
17 other people completed this guide.
Author
with
Nathan Powell
1,584 Reputation
3 Guides authored
Cal Poly, Team 11-49, Amido Spring 2014 Member of Cal Poly, Team 11-49, Amido Spring 2014
CPSU-AMIDO-S14S11G49
4 Members
48 Guides authored
28 Guide Comments
Hi!
Thank you very much for this tuto. But wher can we acquire the screen ???
Thanks a lot.
AB
aaa - Reply Share
Where can you buy replacement screen?
Yele Olaniyi - Reply Share
I'm also finding it difficult to buy a replacement screen too. Has anyone discovered some. I thought this website was selling some not too long ago. Any more coming in?
Rochelle - Reply Share
Hi guys,
is it possible to detach the display unit from the protective plastic cover (I think it's not glass) ?
alexxtodorov - Reply Share
Does anyone know where to get the replacement screen?
MrGratts - Reply Share
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 108
All Time: 55,033
