Samsung Gear 2 Neo Speaker Replacement
    1. Samsung Gear 2 Neo Speaker Replacement, Battery: step 1, image 1 of 1
      • Remove the wristband by sliding the metal pins located on both sides of the wrist band, and pulling the wristband off.
      Ask FixBot
    2. Samsung Gear 2 Neo Speaker Replacement: step 2, image 1 of 2 Samsung Gear 2 Neo Speaker Replacement: step 2, image 2 of 2
      • Use a T5 Torx Screwdriver to remove the 4 (0.4 mm) screws located on the back of the watch.
      Ask FixBot
    3. Samsung Gear 2 Neo Speaker Replacement: step 3, image 1 of 1
      • Slide the opening tool in between the two halves of the case and slide along the edge of the watch while gently prying the back cover away from the face of the watch.
      Ask FixBot
    4. Samsung Gear 2 Neo Speaker Replacement: step 4, image 1 of 2 Samsung Gear 2 Neo Speaker Replacement: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Use a pair of tweezers to peel the battery ribbon cable off of the back cover.
      • Avoid damaging the gold terminals on the ribbon cable.
      • When reassembling, make sure that the yellow strip snaps back on to the black pin.
      • The pin is located, and marked on the picture.
      • Pull up on the tab that says, “Pull”, the battery will lift straight out.
      Ask FixBot
    1. Samsung Gear 2 Neo Speaker Replacement, Speaker: step 5, image 1 of 1
      Buy
      • Use a pair of tweezers to remove the rubber gasket. It should come off with ease.
      Ask FixBot
    2. Samsung Gear 2 Neo Speaker Replacement: step 6, image 1 of 1
      • Using the fine tweezers, pull up on the speaker ribbon cable until separated from the back cover. Make sure to approach it like in the picture otherwise it may not come off cleanly.
      • To lift out the speaker, place the tweezers underneath the speaker at the top left corner of the speaker and pry it up.
      Ask FixBot
Victor Yore
705 Reputation
5 Guides authored
USF Tampa, Team 5-6, Blackwell Fall 2015 Member of USF Tampa, Team 5-6, Blackwell Fall 2015
USFT-BLACKWELL-F15S5G6
3 Members
30 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 26
All Time: 1,378
