Introduction
After prolonged use, the battery may not hold as long of a charge as it did initially. In this case, the battery will need to be replaced. Do not worry, because battery replacement on the Samsung Gear 2 Neo is one of the easier repairs to complete.
Remove the wristband by sliding the metal pins located on both sides of the wrist band, and pulling the wristband off.
10 other people completed this guide.
7 Guide Comments
I’m not sure why the comment was lost in my inbox. To answer the question regard the gold charging pins, the ones visible in step 2 for the first picture, you’d have to slide a pair of tweezers underneath the blue chip the one seen in step 4. this is dangerous as it’s more integrated to the case than the other parts. At that point you’d need to find a replacement pin set. I haven’t personally worked with the watch for sometime as i no longer have it due to the fact it needed to be returned. In other words this is only a best guess from my experience working with the watch. You might need to unhook the gold tab underneath the blue chip to give yourself a little extra room.
If my gear 2. Neo is being inside water and switching on the display is blurry sounds are working but I cannot see a digital screen what should I do to fix it
