Samsung Galaxy Z Flip 5 Back Glass Replacement
  1. Samsung Galaxy Z Flip 5 Back Glass Replacement, Back Glass: step 1, image 1 of 2 Samsung Galaxy Z Flip 5 Back Glass Replacement, Back Glass: step 1, image 2 of 2
    • Ensure the phone's battery is below 25% to minimize the risk of battery issues during repair.
    • Turn off your phone and unplug it from the charger before you begin the repair.
  2. Samsung Galaxy Z Flip 5 Back Glass Replacement: step 2, image 1 of 2 Samsung Galaxy Z Flip 5 Back Glass Replacement: step 2, image 2 of 2
    • Apply low heat with a heat gun or medium heat with a hairdryer around the edges of the back glass for about one minute to soften the adhesive. Keep the heat source moving and avoid overheating.
    • Keep the heat source around an inch from the back glass.
    • After heating the device, use caution when handling the device.
    • Ensure you are working on a stable, non-flammable surface when using the heat gun.
  3. Samsung Galaxy Z Flip 5 Back Glass Replacement: step 3, image 1 of 3 Samsung Galaxy Z Flip 5 Back Glass Replacement: step 3, image 2 of 3 Samsung Galaxy Z Flip 5 Back Glass Replacement: step 3, image 3 of 3
    • Gently insert the tip of an opening pick or thin plastic card into the seam between the back glass and frame.
    • Carefully slide the pick along all edges using a gentle sawing motion to detach the adhesive.
    • Apply more heat if you encounter resistance. Avoid inserting the pick too deeply.
  4. Samsung Galaxy Z Flip 5 Back Glass Replacement: step 4, image 1 of 3 Samsung Galaxy Z Flip 5 Back Glass Replacement: step 4, image 2 of 3 Samsung Galaxy Z Flip 5 Back Glass Replacement: step 4, image 3 of 3
    • Once the back glass is mostly detached, remove it from the phone carefully.
  5. Samsung Galaxy Z Flip 5 Back Glass Replacement: step 5, image 1 of 3 Samsung Galaxy Z Flip 5 Back Glass Replacement: step 5, image 2 of 3 Samsung Galaxy Z Flip 5 Back Glass Replacement: step 5, image 3 of 3
    • Gently scrape away the old adhesive from the phone frame using a plastic spudger or cloth.
    • For stubborn spots, lightly dampen a lint-free cloth with isopropyl alcohol (90%+) and wipe.
  6. Samsung Galaxy Z Flip 5 Back Glass Replacement: step 6, image 1 of 1
    • After replacing the back glass, apply gentle pressure by hand or use a rubber band to hold it in place until the adhesive fully cures.
redalva00
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 14
Past 7 Days: 61
Past 30 Days: 278
All Time: 3,919
