Samsung Galaxy Y Motherboard Replacement
  1. Samsung Galaxy Y Motherboard Replacement, Back Panel: step 1, image 1 of 3 Samsung Galaxy Y Motherboard Replacement, Back Panel: step 1, image 2 of 3 Samsung Galaxy Y Motherboard Replacement, Back Panel: step 1, image 3 of 3
    • Use the blue plastic opening tool to pry the back-panel off of the device.
  2. Samsung Galaxy Y Motherboard Replacement, Motherboard: step 2, image 1 of 3 Samsung Galaxy Y Motherboard Replacement, Motherboard: step 2, image 2 of 3 Samsung Galaxy Y Motherboard Replacement, Motherboard: step 2, image 3 of 3
    • Use a Phillips #000 screwdriver to remove the four 5mm screws located in the corner of the interior back panel.
    • Remove the SD card as well by sliding the card out of its slot.
  3. Samsung Galaxy Y Motherboard Replacement: step 3, image 1 of 2 Samsung Galaxy Y Motherboard Replacement: step 3, image 2 of 2
    • Use the metal pry tool to separate the interior back panel from the interior hardware and screen.
  4. Samsung Galaxy Y Motherboard Replacement: step 4, image 1 of 3 Samsung Galaxy Y Motherboard Replacement: step 4, image 2 of 3 Samsung Galaxy Y Motherboard Replacement: step 4, image 3 of 3
    • Disconnect the orange motherboard connection, then remove the interior hardware from the front screen display.
  5. Samsung Galaxy Y Motherboard Replacement: step 5, image 1 of 3 Samsung Galaxy Y Motherboard Replacement: step 5, image 2 of 3 Samsung Galaxy Y Motherboard Replacement: step 5, image 3 of 3
    • Use a Phillips #000 screwdriver to remove the five 2mm screws located in the corner of the silver protective panel.
    • If the motherboard is cracked or damaged, then replace with a new one.
Peggi Trask
109 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 30
Past 30 Days: 62
All Time: 1,273
