Samsung Galaxy Y LCD Display Replacement
    1. Samsung Galaxy Y LCD Display Replacement, Back Panel: step 1, image 1 of 3 Samsung Galaxy Y LCD Display Replacement, Back Panel: step 1, image 2 of 3 Samsung Galaxy Y LCD Display Replacement, Back Panel: step 1, image 3 of 3
      • Use the blue plastic opening tool to pry the back-panel off of the device.
      Ask FixBot
    1. Samsung Galaxy Y LCD Display Replacement, LCD Display: step 2, image 1 of 3 Samsung Galaxy Y LCD Display Replacement, LCD Display: step 2, image 2 of 3 Samsung Galaxy Y LCD Display Replacement, LCD Display: step 2, image 3 of 3
      • Use a Phillips #000 screwdriver to remove the four 5mm screws located in the corner of the interior back panel.
      • Remove the SD card as well by sliding the card out of it's slot.
      Ask FixBot
    2. Samsung Galaxy Y LCD Display Replacement: step 3, image 1 of 2 Samsung Galaxy Y LCD Display Replacement: step 3, image 2 of 2
      • Use the metal pry tool to separate the interior back panel from the interior hardware and screen.
      Ask FixBot
    3. Samsung Galaxy Y LCD Display Replacement: step 4, image 1 of 3 Samsung Galaxy Y LCD Display Replacement: step 4, image 2 of 3 Samsung Galaxy Y LCD Display Replacement: step 4, image 3 of 3
      • Disconnect the orange motherboard connection, then remove the interior hardware from the front screen display.
      Ask FixBot
    4. Samsung Galaxy Y LCD Display Replacement: step 5, image 1 of 2 Samsung Galaxy Y LCD Display Replacement: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Gently remove the LCD screen lens from the outer screen using a pair of tweezers and the metal pry tool. Replace the faulty LCD.
      • The LCD maybe be glued in place, so the device might need to be heated to remove the part.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 65
All Time: 1,260
