Samsung Galaxy Watch3 Motherboard Replacement
    1. Samsung Galaxy Watch3 Motherboard Replacement, Unfasten the back cover screws: step 1, image 1 of 1
      • Before starting repairs, take your watch off the charger and power it down.
      • Use a Tri-point Y00 driver to unfasten the four screws on the back of the watch.
      • Don’t worry about removing the screws, they will stay in place in the back cover.
      Ask FixBot
    2. Samsung Galaxy Watch3 Motherboard Replacement, Wedge open the back cover: step 2, image 1 of 2 Samsung Galaxy Watch3 Motherboard Replacement, Wedge open the back cover: step 2, image 2 of 2
      • Insert an opening tool between the back cover and the metal housing.
      • Twist the opening tool to create a wider gap.
      • Don't fully remove the back cover just yet. The sensor flex cable is still connected to the motherboard.
      Ask FixBot
    3. Samsung Galaxy Watch3 Motherboard Replacement, Disconnect the sensor flex cable: step 3, image 1 of 3 Samsung Galaxy Watch3 Motherboard Replacement, Disconnect the sensor flex cable: step 3, image 2 of 3 Samsung Galaxy Watch3 Motherboard Replacement, Disconnect the sensor flex cable: step 3, image 3 of 3
      • Lay the watch face down.
      • Carefully lift the back cover up from the edge with the buttons to access the sensor connector.
      • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
      Ask FixBot
    4. Samsung Galaxy Watch3 Motherboard Replacement, Remove the back cover: step 4, image 1 of 2 Samsung Galaxy Watch3 Motherboard Replacement, Remove the back cover: step 4, image 2 of 2
      • Remove the back cover.
      • Make sure the rubber gasket (marked red) is undamaged. If damaged replace it with a new one during reassembly to maintain proper water resistance.
      Ask FixBot
    1. Samsung Galaxy Watch3 Motherboard Replacement, Unplug the three connectors: step 5, image 1 of 3 Samsung Galaxy Watch3 Motherboard Replacement, Unplug the three connectors: step 5, image 2 of 3 Samsung Galaxy Watch3 Motherboard Replacement, Unplug the three connectors: step 5, image 3 of 3
      • Use the flat end of a spudger to disconnect the flex cables of the side buttons, the display and the hall sensor.
      Ask FixBot
    2. Samsung Galaxy Watch3 Motherboard Replacement, Unfasten the motherboard screw: step 6, image 1 of 1
      • Remove the Phillips #00 screw.
      Ask FixBot
    3. Samsung Galaxy Watch3 Motherboard Replacement, Remove the motherboard: step 7, image 1 of 2 Samsung Galaxy Watch3 Motherboard Replacement, Remove the motherboard: step 7, image 2 of 2
      Tool used on this step:
      Buy
      • The motherboard is held in place by two small plastic clips.
      • Use a pair of blunt tweezers to lift the motherboard out from underneath the plastic clips towards the buttons.
      • Remove the motherboard.
      Ask FixBot
If possible, turn on your device and test your repair before resealing.
2 other people completed this guide.
Tobias Isakeit
135,066 Reputation
189 Guides authored
1 Guide Comment
What is the cost of R845 mother board of Samsung watch 3- 45 mm
Jayanta Roy - Reply Share
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 61
All Time: 3,488
