Samsung Galaxy Watch3 Display Replacement
Views: 12K
View statistics:
Past 24 Hours:
3
Past 7 Days:
37
Past 30 Days:
146
All Time:
11,836
Comments: 8
7 comments on steps, 1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 45 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Use this guide to replace a cracked or broken screen on your Samsung Galaxy Watch3.
Parts
Tools
    1. Samsung Galaxy Watch3 Display Replacement, Unfasten the back cover screws: step 1, image 1 of 1
      • Before starting repairs, take your watch off the charger and power it down.
      • Use a Tri-point Y00 driver to unfasten the four screws on the back of the watch.
      • Don’t worry about removing the screws, they will stay in place in the back cover.
      Ask FixBot
    2. Samsung Galaxy Watch3 Display Replacement, Wedge open the back cover: step 2, image 1 of 2 Samsung Galaxy Watch3 Display Replacement, Wedge open the back cover: step 2, image 2 of 2
      • Insert an opening tool between the back cover and the metal housing.
      • Twist the opening tool to create a wider gap.
      • Don't fully remove the back cover just yet. The sensor flex cable is still connected to the motherboard.
      Ask FixBot
    3. Samsung Galaxy Watch3 Display Replacement, Disconnect the sensor flex cable: step 3, image 1 of 3 Samsung Galaxy Watch3 Display Replacement, Disconnect the sensor flex cable: step 3, image 2 of 3 Samsung Galaxy Watch3 Display Replacement, Disconnect the sensor flex cable: step 3, image 3 of 3
      • Lay the watch face down.
      • Carefully lift the back cover up from the edge with the buttons to access the sensor connector.
      • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
      Ask FixBot
    4. Samsung Galaxy Watch3 Display Replacement, Remove the back cover: step 4, image 1 of 2 Samsung Galaxy Watch3 Display Replacement, Remove the back cover: step 4, image 2 of 2
      • Remove the back cover.
      • Make sure the rubber gasket (marked red) is undamaged. If damaged replace it with a new one during reassembly to maintain proper water resistance.
      Ask FixBot
    1. Samsung Galaxy Watch3 Display Replacement, Unplug the display connector: step 5, image 1 of 2 Samsung Galaxy Watch3 Display Replacement, Unplug the display connector: step 5, image 2 of 2
      • Use the flat end of a spudger to pry up and disconnect the display flex cable from the motherboard.
      Ask FixBot
    2. Samsung Galaxy Watch3 Display Replacement, Loosen the core assembly: step 6, image 1 of 2 Samsung Galaxy Watch3 Display Replacement, Loosen the core assembly: step 6, image 2 of 2
      • The core's plastic frame fits tightly within the watch's metal housing.
      • Place the corner of the flat end of a spudger in the small opening of the barometric sensor, on the opposite side of the display connector.
      • Twist and tilt the spudger to lever the core assembly out of the metal housing.
      Ask FixBot
    3. Samsung Galaxy Watch3 Display Replacement, Remove the core assembly: step 7, image 1 of 3 Samsung Galaxy Watch3 Display Replacement, Remove the core assembly: step 7, image 2 of 3 Samsung Galaxy Watch3 Display Replacement, Remove the core assembly: step 7, image 3 of 3
      • Carefully thread the display flex cable through the gap on the core's plastic frame.
      • Remove the core assembly.
      Ask FixBot
    1. Samsung Galaxy Watch3 Display Replacement, Push out the display: step 8, image 1 of 2 Samsung Galaxy Watch3 Display Replacement, Push out the display: step 8, image 2 of 2
      • If your display is cracked, keep glass shards contained by applying a strip of tape over the glass."
      • Use your finger to steadily push the display down through the watch's metal housing to loosen the adhesive.
      • Lightly heating the display with a hair dryer or iOpener can help soften the adhesive.
      • Remove the display.
      Ask FixBot
If possible, turn on your device and test your repair before reassembly.
3 other people completed this guide.
Tobias Isakeit
136,079 Reputation
189 Guides authored
1 Guide Comment
Any idea how to remove the rotating bezel?
Azhar Suhaimi - Reply Share
Past 24 Hours: 3
Past 7 Days: 37
Past 30 Days: 146
All Time: 11,836
