Samsung Galaxy Watch3 Battery Replacement
Views: 53K
View statistics:
Past 24 Hours:
17
Past 7 Days:
115
Past 30 Days:
486
All Time:
53,216
Comments: 27
9 comments on steps, 18 guide comments.
Go to guide comments
Completed: 26
26 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Use this guide to replace a worn-out or dead battery in your Samsung Galaxy Watch3.
If your battery is swollen, take appropriate precautions. For your safety, discharge your battery below 25% before disassembling your smartwatch. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
You’ll need replacement adhesive to reattach a new battery when reassembling the device.
Parts
Tools
    1. Samsung Galaxy Watch3 Battery Replacement, Unfasten the back cover screws: step 1, image 1 of 1
      • Before starting repairs, take your watch off the charger and power it down.
      • Use a Tri-point Y00 driver to unfasten the four screws on the back of the watch.
      • Don’t worry about removing the screws, they will stay in place in the back cover.
      Ask FixBot
    2. Samsung Galaxy Watch3 Battery Replacement, Wedge open the back cover: step 2, image 1 of 2 Samsung Galaxy Watch3 Battery Replacement, Wedge open the back cover: step 2, image 2 of 2
      • Insert an opening tool between the back cover and the metal housing.
      • Twist the opening tool to create a wider gap.
      • Don't fully remove the back cover just yet. The sensor flex cable is still connected to the motherboard.
      Ask FixBot
    3. Samsung Galaxy Watch3 Battery Replacement, Disconnect the sensor flex cable: step 3, image 1 of 3 Samsung Galaxy Watch3 Battery Replacement, Disconnect the sensor flex cable: step 3, image 2 of 3 Samsung Galaxy Watch3 Battery Replacement, Disconnect the sensor flex cable: step 3, image 3 of 3
      • Lay the watch face down.
      • Carefully lift the back cover up from the edge with the buttons to access the sensor connector.
      • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
      Ask FixBot
    4. Samsung Galaxy Watch3 Battery Replacement, Remove the back cover: step 4, image 1 of 2 Samsung Galaxy Watch3 Battery Replacement, Remove the back cover: step 4, image 2 of 2
      • Remove the back cover.
      • Make sure the rubber gasket (marked red) is undamaged. If damaged replace it with a new one during reassembly to maintain proper water resistance.
      Ask FixBot
    1. Samsung Galaxy Watch3 Battery Replacement, Unplug the three connectors: step 5, image 1 of 3 Samsung Galaxy Watch3 Battery Replacement, Unplug the three connectors: step 5, image 2 of 3 Samsung Galaxy Watch3 Battery Replacement, Unplug the three connectors: step 5, image 3 of 3
      • Use the flat end of a spudger to disconnect the flex cables of the side buttons, the display and the hall sensor.
      Ask FixBot
    2. Samsung Galaxy Watch3 Battery Replacement, Unfasten the motherboard screw: step 6, image 1 of 1
      • Remove the Phillips #00 screw.
      Ask FixBot
    3. Samsung Galaxy Watch3 Battery Replacement, Remove the motherboard: step 7, image 1 of 2 Samsung Galaxy Watch3 Battery Replacement, Remove the motherboard: step 7, image 2 of 2
      Tool used on this step:
      Buy
      • The motherboard is held in place by two small plastic clips.
      • Use a pair of blunt tweezers to lift the motherboard out from underneath the plastic clips towards the buttons.
      • Remove the motherboard.
      Ask FixBot
    1. Samsung Galaxy Watch3 Battery Replacement, Lever up the battery: step 8, image 1 of 3 Samsung Galaxy Watch3 Battery Replacement, Lever up the battery: step 8, image 2 of 3 Samsung Galaxy Watch3 Battery Replacement, Lever up the battery: step 8, image 3 of 3
      • Place the flat end of a supdger in the small gap between the plastic frame and the battery, opposite to the display cable.
      • Carefully lever the battery up and out of its recess.
      • The battery is adhered to the core with light adhesive, so take your time.
      • Don't try to remove the battery completely yet, as its connector is still adhered to the core.
      Ask FixBot
    2. Samsung Galaxy Watch3 Battery Replacement, Remove the battery: step 9, image 1 of 2 Samsung Galaxy Watch3 Battery Replacement, Remove the battery: step 9, image 2 of 2
      Tesa 61395 Tape
      $8.95
      Buy
      • Lift the battery up a little in order to access its glued down connector cable.
      • Use a pair of blunt tweezers to lift up the battery connector which is secured with some light adhesive.
      • You will most likely be able to re-use the adhesive to fix the new battery in place. If not replace it with double sided or pre-cut adhesive tape.
      • Remove the battery.
      Ask FixBot
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
26 other people completed this guide.
Tobias Isakeit
136,104 Reputation
189 Guides authored
18 Guide Comments
Once I had the correct tools and replacement battery, fixing was easy. Tyvm!
Jeremy Salazar - Reply Share
One question, where can I find an authorized battery for this watch? or one that you highly recommend. Thanks.
**Edit - Your store doesn’t have a 45mm battery for my Galaxy Watch 3. Only 42 and 46.
Gilberto Garcia - Reply Share
The 42 and 46 mm models are the first Galaxy Watch sizes. We ’re working on getting the Watch3 batteries and parts but it may take some time.
Tobias Isakeit - Reply Share
Hi, is it possible to put the battery from samsung watch 472mAh, on samsung watch 3, instead of 340mAh?
Andrey Irnazarov - Reply Share
Hi Andrey, short answer is no—although basically a good idea. But even if you cut the battery contact plate to fit (cut off the part with the alignment hole) its polarity is inverted. The Watch3 contact plate has -/+ (noted under the cable) whereas the original has +/-. Also the original Galaxy Watch battery is much bigger than the one in the Watch3. So it won’t fit inside the recess. Here is an image with the Watch3 battery on top of the original battery.
Past 24 Hours: 17
Past 7 Days: 115
Past 30 Days: 486
All Time: 53,216
