Samsung Galaxy Watch Motherboard Replacement
  1. Samsung Galaxy Watch Motherboard Replacement, Opening Procedure: step 1, image 1 of 1
    • Remove the four Tri-point #00 screws (4.2 mm length) on the backside of the watch.
    Ask FixBot
  2. Samsung Galaxy Watch Motherboard Replacement: step 2, image 1 of 2 Samsung Galaxy Watch Motherboard Replacement: step 2, image 2 of 2
    • Use an opening tool to get between the back cover and the metal housing of the watch.
    • Carefully pry the plastic back cover open.
    • Don't remove the back cover yet. There is a flex cable running to the core assembly inside.
    Ask FixBot
  3. Samsung Galaxy Watch Motherboard Replacement: step 3, image 1 of 2 Samsung Galaxy Watch Motherboard Replacement: step 3, image 2 of 2
    • Lay down the watch and lift the back cover to access the sensor connector on the motherboard.
    Ask FixBot
  4. Samsung Galaxy Watch Motherboard Replacement: step 4, image 1 of 2 Samsung Galaxy Watch Motherboard Replacement: step 4, image 2 of 2
    • Use a spudger to disconnect the sensor flex cable from the motherboard.
    Ask FixBot
  5. Samsung Galaxy Watch Motherboard Replacement: step 5, image 1 of 3 Samsung Galaxy Watch Motherboard Replacement: step 5, image 2 of 3 Samsung Galaxy Watch Motherboard Replacement: step 5, image 3 of 3
    • Remove the back cover.
    • When closing the watch make sure the rubber gasket is undamaged or replace it with a new one.
    Ask FixBot
  6. Samsung Galaxy Watch Motherboard Replacement, Core Assembly Removal: step 6, image 1 of 2 Samsung Galaxy Watch Motherboard Replacement, Core Assembly Removal: step 6, image 2 of 2
    • Use a spudger to disconnect the display flex cable from the motherboard.
    Ask FixBot
  7. Samsung Galaxy Watch Motherboard Replacement: step 7, image 1 of 2 Samsung Galaxy Watch Motherboard Replacement: step 7, image 2 of 2
    • Lift the core unit out of the housing.
    • The core's plastic frame sits tight inside the housing.
    • Carefully thread the display flex cable through the gap of the core's plastic frame.
    Ask FixBot
  8. Samsung Galaxy Watch Motherboard Replacement, Motherboard: step 8, image 1 of 2 Samsung Galaxy Watch Motherboard Replacement, Motherboard: step 8, image 2 of 2
    • Use a spudger to disconnect the hall sensor flex cable.
    Ask FixBot
  9. Samsung Galaxy Watch Motherboard Replacement: step 9, image 1 of 3 Samsung Galaxy Watch Motherboard Replacement: step 9, image 2 of 3 Samsung Galaxy Watch Motherboard Replacement: step 9, image 3 of 3
    Tool used on this step:
    Buy
    • Use a pair of tweezers to gently peel both button cables from the plastic frame.
    • The button cables have metal plates behind them. These plates should remain on the cables.
    Ask FixBot
  10. Samsung Galaxy Watch Motherboard Replacement: step 10, image 1 of 1
    • Remove the single Phillips #00 screw (3.4 mm length).
    Ask FixBot
  11. Samsung Galaxy Watch Motherboard Replacement: step 11, image 1 of 3 Samsung Galaxy Watch Motherboard Replacement: step 11, image 2 of 3 Samsung Galaxy Watch Motherboard Replacement: step 11, image 3 of 3
    • Insert a spudger into the small gap underneath the motherboard where the cutout in the plastic frame is.
    • Lift the motherboard by twisting the spudger.
    • Slide the motherboard out from under the plastic tab.
    Ask FixBot
  12. Samsung Galaxy Watch Motherboard Replacement: step 12, image 1 of 1
    • Remove the motherboard.
    Ask FixBot
If possible, turn on your device and test your repair before resealing.
9 other people completed this guide.
Tobias Isakeit
134,001 Reputation
189 Guides authored
7 Guide Comments
Anyone know where to purchase a Galaxy Watch mother board?
lorne serpa - Reply Share
What is the part number, or where can you get the motherboard?
Nick Henthorn - Reply Share
Where can the motherboard be purchased from for Galaxy Watch ?
Mohammed Aamir - Reply Share
I got a motherboard on ebay. Including import duties it was something like 90$. Shipped to Denmark.
Definitely cheaper than repair shop and absolutely more fun! :)
Agris Jurjans - Reply Share
Hello,
Do you know if switching a motherboard from a GW46 Bluetooth only (R800) to a GW46 LTE (R805) is a straight swap or additional parts are needed?
As my R800 sensors are dead and i need to replace the motherboard and the back cover anyway.
Thanks
BRazvy - Reply Share
Past 24 Hours: 5
Past 7 Days: 91
Past 30 Days: 231
All Time: 16,909
