Samsung Galaxy Watch Display Replacement
Views: 83K
View statistics:
Past 24 Hours:
16
Past 7 Days:
111
Past 30 Days:
520
All Time:
82,598
Comments: 35
34 comments on steps, 1 guide comment.
Go to guide comments
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 - 55 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace a cracked or broken screen on your Galaxy Watch.
Parts
Tools
    1. Samsung Galaxy Watch Display Replacement, Opening Procedure: step 1, image 1 of 1
      • Remove the four Tri-point #00 screws (4.2 mm length) on the backside of the watch.
      Ask FixBot
    2. Samsung Galaxy Watch Display Replacement: step 2, image 1 of 2 Samsung Galaxy Watch Display Replacement: step 2, image 2 of 2
      • Use an opening tool to get between the back cover and the metal housing of the watch.
      • Carefully pry the plastic back cover open.
      • Don't remove the back cover yet. There is a flex cable running to the core assembly inside.
      Ask FixBot
    3. Samsung Galaxy Watch Display Replacement: step 3, image 1 of 2 Samsung Galaxy Watch Display Replacement: step 3, image 2 of 2
      • Lay down the watch and lift the back cover to access the sensor connector on the motherboard.
      Ask FixBot
    4. Samsung Galaxy Watch Display Replacement: step 4, image 1 of 2 Samsung Galaxy Watch Display Replacement: step 4, image 2 of 2
      • Use a spudger to disconnect the sensor flex cable from the motherboard.
      Ask FixBot
    5. Samsung Galaxy Watch Display Replacement: step 5, image 1 of 3 Samsung Galaxy Watch Display Replacement: step 5, image 2 of 3 Samsung Galaxy Watch Display Replacement: step 5, image 3 of 3
      • Remove the back cover.
      • When closing the watch make sure the rubber gasket is undamaged or replace it with a new one.
      Ask FixBot
    1. Samsung Galaxy Watch Display Replacement, Core Assembly Removal: step 6, image 1 of 2 Samsung Galaxy Watch Display Replacement, Core Assembly Removal: step 6, image 2 of 2
      • Use a spudger to disconnect the display flex cable from the motherboard.
      Ask FixBot
    2. Samsung Galaxy Watch Display Replacement: step 7, image 1 of 2 Samsung Galaxy Watch Display Replacement: step 7, image 2 of 2
      • Lift the core unit out of the housing.
      • The core's plastic frame sits tight inside the housing.
      • Carefully thread the display flex cable through the gap of the core's plastic frame.
      Ask FixBot
    1. Samsung Galaxy Watch Display Replacement, Display: step 8, image 1 of 1
      • If necessary apply some tape over the display to avoid any injury from glass shards.
      Ask FixBot
    2. Samsung Galaxy Watch Display Replacement: step 9, image 1 of 2 Samsung Galaxy Watch Display Replacement: step 9, image 2 of 2
      • Use your finger or thumb to steadily push down on the display to loosen the adhesive.
      • Heating the display with a hair dryer or iOpener helps softening the adhesive.
      • Remove the display.
      Ask FixBot
9 other people completed this guide.
Tobias Isakeit
136,007 Reputation
189 Guides authored
1 Guide Comment
Hi does this process work with the galaxy 5 watch?
Rey Thomas Jude Ho - Reply Share
Past 24 Hours: 16
Past 7 Days: 111
Past 30 Days: 520
All Time: 82,598
