Samsung Galaxy Watch Active2 Motherboard Replacement
    1. Samsung Galaxy Watch Active2 Motherboard Replacement, Turn off the watch: step 1, image 1 of 2 Samsung Galaxy Watch Active2 Motherboard Replacement, Turn off the watch: step 1, image 2 of 2
      • Turn off the Galaxy Watch Active2 by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
      • When the "Power off" symbol appears, tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
      Ask FixBot
    2. Samsung Galaxy Watch Active2 Motherboard Replacement, Remove the rear screws: step 2, image 1 of 1
      • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
      Ask FixBot
    3. Samsung Galaxy Watch Active2 Motherboard Replacement, Separate the back cover from the housing: step 3, image 1 of 3 Samsung Galaxy Watch Active2 Motherboard Replacement, Separate the back cover from the housing: step 3, image 2 of 3 Samsung Galaxy Watch Active2 Motherboard Replacement, Separate the back cover from the housing: step 3, image 3 of 3
      • Use an opening pick and place it between the plastic back cover and the metal housing near the buttons.
      • Push the opening pick into the gap to separate the back cover from the housing.
      • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
      Ask FixBot
    4. Samsung Galaxy Watch Active2 Motherboard Replacement, Disconnect the sensor array: step 4, image 1 of 2 Samsung Galaxy Watch Active2 Motherboard Replacement, Disconnect the sensor array: step 4, image 2 of 2
      • Carefully lift the back cover to access the sensor array connector.
      • Use a spudger to disconnect the sensor array from the motherboard.
      Ask FixBot
    5. Samsung Galaxy Watch Active2 Motherboard Replacement, Remove the back cover: step 5, image 1 of 1
      • Remove the back cover.
      Ask FixBot
    1. Samsung Galaxy Watch Active2 Motherboard Replacement, Disconnect the display and speaker: step 6, image 1 of 3 Samsung Galaxy Watch Active2 Motherboard Replacement, Disconnect the display and speaker: step 6, image 2 of 3 Samsung Galaxy Watch Active2 Motherboard Replacement, Disconnect the display and speaker: step 6, image 3 of 3
      • Use a spudger to disconnect the display assembly and the speaker.
      Ask FixBot
    2. Samsung Galaxy Watch Active2 Motherboard Replacement, Disconnect the barometric sensor, buttons, and mic: step 7, image 1 of 3 Samsung Galaxy Watch Active2 Motherboard Replacement, Disconnect the barometric sensor, buttons, and mic: step 7, image 2 of 3 Samsung Galaxy Watch Active2 Motherboard Replacement, Disconnect the barometric sensor, buttons, and mic: step 7, image 3 of 3
      • Use a spudger to disconnect the barometric sensor, the buttons, and the microphone.
      Ask FixBot
    3. Samsung Galaxy Watch Active2 Motherboard Replacement, Lift the core assembly: step 8, image 1 of 2 Samsung Galaxy Watch Active2 Motherboard Replacement, Lift the core assembly: step 8, image 2 of 2
      • Place a spudger underneath the motherboard at the top right next to the display connector.
      • Slightly twist and lever the spudger to loosen the core assembly.
      • It might help to also check the comments below this and the next step if you’re having difficulties.
      Ask FixBot
    4. Samsung Galaxy Watch Active2 Motherboard Replacement, Remove the core assembly: step 9, image 1 of 3 Samsung Galaxy Watch Active2 Motherboard Replacement, Remove the core assembly: step 9, image 2 of 3 Samsung Galaxy Watch Active2 Motherboard Replacement, Remove the core assembly: step 9, image 3 of 3
      • Grab the core assembly and carefully slide it out from under the cables.
      • Remove the core assembly.
      Ask FixBot
    1. Samsung Galaxy Watch Active2 Motherboard Replacement, Flip the Core Assembly: step 10, image 1 of 1
      • Flip the core assembly over so the motherboard faces down.
      Ask FixBot
    2. Samsung Galaxy Watch Active2 Motherboard Replacement, Undo the top button: step 11, image 1 of 2 Samsung Galaxy Watch Active2 Motherboard Replacement, Undo the top button: step 11, image 2 of 2
      • Use the tip of an opening pick to peel the top button off the plastic frame.
      Ask FixBot
    3. Samsung Galaxy Watch Active2 Motherboard Replacement, Remove the motherboard screw: step 12, image 1 of 1
      • Use a Phillips screwdriver to remove the 4.4 mm-long screw holding the motherboard in place.
      Ask FixBot
    4. Samsung Galaxy Watch Active2 Motherboard Replacement, Free the motherboard: step 13, image 1 of 2 Samsung Galaxy Watch Active2 Motherboard Replacement, Free the motherboard: step 13, image 2 of 2
      • Place the flat end of a spudger between the motherboard and the plastic frame near the copper coil at the bottom right.
      • Twist the spudger to free the motherboard from the plastic tabs.
      Ask FixBot
    5. Samsung Galaxy Watch Active2 Motherboard Replacement, Remove the motherboard: step 14, image 1 of 1
      • Slide the motherboard out from under the remaining plastic tabs to remove it.
      Ask FixBot
6 other people completed this guide.
Tobias Isakeit
135,066 Reputation
189 Guides authored
13 Guide Comments
Hi, I am having issues with bluetooth, is it a replacement or do I need to swap the MB? Thank you
Bruno Albin - Reply Share
When you have ruled out any software issues (tried restart, factory reset, software update, etc) then this is most likely a MB replacement since all the modules are integrated on that tiny thing.
Tobias Isakeit - Reply Share
does the watch active have the same motherboard as the watch active 2
aqoullam6 - Reply Share
Nope, the Watch Active has a different motherboard.
My watch stopped vibrating all together, which part do I need to replace?
Melissa McEleney - Reply Share
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 100
All Time: 12,056
