Samsung Galaxy Watch Active2 Back Cover Replacement
Views: 46K
View statistics:
Past 24 Hours:
8
Past 7 Days:
46
Past 30 Days:
277
All Time:
45,960
Comments: 21
15 comments on steps, 6 guide comments.
Go to guide comments
Completed: 14
14 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace a defective back cover of your Samsung Galaxy Watch Active2. You can also use this guide to open your smartwatch for any other repair.
Tools
    1. Samsung Galaxy Watch Active2 Back Cover Replacement, Turn off the watch: step 1, image 1 of 2 Samsung Galaxy Watch Active2 Back Cover Replacement, Turn off the watch: step 1, image 2 of 2
      • Turn off the Galaxy Watch Active2 by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
      • When the "Power off" symbol appears, tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
      Ask FixBot
    2. Samsung Galaxy Watch Active2 Back Cover Replacement, Remove the rear screws: step 2, image 1 of 1
      • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
      Ask FixBot
    3. Samsung Galaxy Watch Active2 Back Cover Replacement, Separate the back cover from the housing: step 3, image 1 of 3 Samsung Galaxy Watch Active2 Back Cover Replacement, Separate the back cover from the housing: step 3, image 2 of 3 Samsung Galaxy Watch Active2 Back Cover Replacement, Separate the back cover from the housing: step 3, image 3 of 3
      • Use an opening pick and place it between the plastic back cover and the metal housing near the buttons.
      • Push the opening pick into the gap to separate the back cover from the housing.
      • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
      Ask FixBot
    4. Samsung Galaxy Watch Active2 Back Cover Replacement, Disconnect the sensor array: step 4, image 1 of 2 Samsung Galaxy Watch Active2 Back Cover Replacement, Disconnect the sensor array: step 4, image 2 of 2
      • Carefully lift the back cover to access the sensor array connector.
      • Use a spudger to disconnect the sensor array from the motherboard.
      Ask FixBot
    5. Samsung Galaxy Watch Active2 Back Cover Replacement, Remove the back cover: step 5, image 1 of 1
      • Remove the back cover.
      Ask FixBot
14 other people completed this guide.
Tobias Isakeit
136,104 Reputation
189 Guides authored
6 Guide Comments
What kind of glue would you use if the plastic of the back cover fell off?
Dave Hains - Reply Share
This happened to me as well. I opted to replace the entire adhesive-attached back cover. You can find kits that include a new back with a new adhesive gasket already attached. You just need to take off the old one and make sure it's clean before putting on the new one. I bought this one on ebay: https://www.ebay.com/itm/164638316825
John S. - Reply Share
Hello. Where can i get the back cover with adhesive as a replacement or just the adhesvie? I noticed it is a weird rubbery glue and i cannot source this anywhere.
Arbuzov Paul - Reply Share
Ilona Smit - Reply Share
Why would you use glue? The back is fixed with screws.
If there is a loose part on the back cover you might want to try a glue like the E6000, B7000 or T9000 (there are different combinations out there)
Tobias Isakeit - Reply Share
Past 24 Hours: 8
Past 7 Days: 46
Past 30 Days: 277
All Time: 45,960
