Samsung Galaxy TabPro S Battery Replacement
Views: 21K
View statistics:
Past 24 Hours:
3
Past 7 Days:
56
Past 30 Days:
208
All Time:
20,679
Comments: 25
5 comments on steps, 20 guide comments.
Go to guide comments
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Is your tablet not charging, heating up, or the battery is dying off to quickly?
Then maybe its time to replace your tablet's battery.
This guide will give you step by step instructions on how to replace your tablet's battery.
Tools
    1. Samsung Galaxy TabPro S Battery Replacement, Battery: step 1, image 1 of 1
      • Place the device face down on a flat work surface.
      Ask FixBot
    2. Samsung Galaxy TabPro S Battery Replacement: step 2, image 1 of 2 Samsung Galaxy TabPro S Battery Replacement: step 2, image 2 of 2
      • Heat the iOpener in the microwave for 30 seconds. Then place it on each side for 20 seconds in order to loosen the adhesive sealing on the device.
      Ask FixBot
    3. Samsung Galaxy TabPro S Battery Replacement: step 3, image 1 of 3 Samsung Galaxy TabPro S Battery Replacement: step 3, image 2 of 3 Samsung Galaxy TabPro S Battery Replacement: step 3, image 3 of 3
      • Using the plastic opening tool, open up the back of the device.
      Ask FixBot
    4. Samsung Galaxy TabPro S Battery Replacement: step 4, image 1 of 1
      • Once opened you will notice three locations (boxed in red) that will need to be disconnected in order to proceed.
      Ask FixBot
    5. Samsung Galaxy TabPro S Battery Replacement: step 5, image 1 of 3 Samsung Galaxy TabPro S Battery Replacement: step 5, image 2 of 3 Samsung Galaxy TabPro S Battery Replacement: step 5, image 3 of 3
      • Using the black nylon spudger, for the black ribbon cable you must gently apply pressure up from underneath until you hear a popping sound.
      Ask FixBot
    6. Samsung Galaxy TabPro S Battery Replacement: step 6, image 1 of 2 Samsung Galaxy TabPro S Battery Replacement: step 6, image 2 of 2
      • Use the black nylon spudger tool to gently remove the small orange ribbon cable from the motherboard.
      Ask FixBot
    7. Samsung Galaxy TabPro S Battery Replacement: step 7, image 1 of 2 Samsung Galaxy TabPro S Battery Replacement: step 7, image 2 of 2
      • Use the black nylon spudger tool to gently remove the long orange ribbon cable from the motherboard.
      Ask FixBot
    8. Samsung Galaxy TabPro S Battery Replacement: step 8, image 1 of 2 Samsung Galaxy TabPro S Battery Replacement: step 8, image 2 of 2
      • Using a J000 screwdriver, unscrew the five 3.4 mm Philips screws.
      Ask FixBot
    9. Samsung Galaxy TabPro S Battery Replacement: step 9, image 1 of 3 Samsung Galaxy TabPro S Battery Replacement: step 9, image 2 of 3 Samsung Galaxy TabPro S Battery Replacement: step 9, image 3 of 3
      • After removing the leftmost ribbon cable and all five screws, we can then use a black nylon spudger to lift the battery out of the device.
      Ask FixBot
9 other people completed this guide.
Jyotsna Gone
515 Reputation
2 Guides authored
USF Tampa, Team 1-2, Sullivan Spring 2017 Member of USF Tampa, Team 1-2, Sullivan Spring 2017
USFT-SULLIVAN-S17S1G2
4 Members
24 Guides authored
20 Guide Comments
Can you provide the part number for the battery itself?
Parker University - Reply Share
You fail to draw attention to the very real risk of breaking three small cables (one near the keyboard connector at the bottom, one on the right hand side and on at the right hand top - looking at the back panel with the SAMSUNG label right way up) - if great care is not used when removing the back panel. They are fragile cable, not mush spare length and no easy way to disconnect
Not sure if these cables and what they are attached to, are available as spares but require a more extensive disassembly to replace if they are!
Steve Williams
Steve Williams - Reply Share
do you know if i can get replacement for those cables?
Jin Choi - Reply Share
You are so right I severed the connection to my keyboard only to find out that my tablet and battery are fine but the screen is black because of an upgrade and now I cant use my keyboard to connect the tablet to an external monitor to fix the download. Is there any way to repair that cable? Any Help would be greatly appreciated.
mrv_18 - Reply Share
pretty sure the correct way to take apart this device is to heat off the screen first, then after removing a few screws the metal chassis comes avay from the back avoiding you having to remove the back cover that has small flexed attached. therefore avoiding any chance of damaging the device by incorrect procedure. you should definitely update this guide
BenWilden - Reply Share
Past 24 Hours: 3
Past 7 Days: 56
Past 30 Days: 208
All Time: 20,679
