Samsung Galaxy Tab S3 Display Replacement
    1. Samsung Galaxy Tab S3 Display Replacement, Display: step 1, image 1 of 1
      • To soften the adhesive holding the tablet together, heat up the edges of the glass panel using a heated iOpener on the edge of the device. Alternatively you can use a heat gun to loosen the adhesive.
      • Leave the iOpener on edge for two minutes.
      • Be careful not to burn yourself while handling the hot iOpener. For more information on the iOpener, use the iOpener Instructions Guide.
      Ask FixBot
    2. Samsung Galaxy Tab S3 Display Replacement: step 2, image 1 of 1
      • Place a suction cup near edge that you heated up with the iOpener.
      • Press down on the suction cup to create a seal, and pull up with force to create a separation between the display and the midframe.
      • Use an opening tool to split apart the glass panel from the midframe.
      • Be careful to not break the glass when prying from the frame.
      Ask FixBot
    3. Samsung Galaxy Tab S3 Display Replacement: step 3, image 1 of 1
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • As you continue along the edge using the opening tool, use a plastic card to keep the glass separate from the midframe.
      • You can also use multiple opening picks instead of a plastic card.
      Ask FixBot
    4. Samsung Galaxy Tab S3 Display Replacement: step 4, image 1 of 3 Samsung Galaxy Tab S3 Display Replacement: step 4, image 2 of 3 Samsung Galaxy Tab S3 Display Replacement: step 4, image 3 of 3
      • Pull off the glass panel using the suction cup.
      • As you remove the glass panel, be careful not to tear the ribbon connecting the motherboard to the display.
      • Carefully disconnect the ribbon cable connecting the display assembly to the motherboard. You can disconnect this ribbon from either end.
      Ask FixBot
    5. Samsung Galaxy Tab S3 Display Replacement, Rear glass panel: step 5, image 1 of 2 Samsung Galaxy Tab S3 Display Replacement, Rear glass panel: step 5, image 2 of 2
      • Repeat steps 3 through 7 to remove the rear glass panel on the opposite side of the device.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. If you have removed too much adhesive, you may need to apply more during the reassembly process.
7 other people completed this guide.
Jelly Romero
322 Reputation
1 Guide authored
Cal Poly, Team S22-G4, Maness Spring 2018 Member of Cal Poly, Team S22-G4, Maness Spring 2018
CPSU-MANESS-S18S22G4
5 Members
60 Guides authored
6 Guide Comments
Thank you so much, It helped me so much.
MRxROBOT - Reply Share
What if the digitizer is ok and only the glass cover is cracked
stargazer_jbl - Reply Share
if you need more adhesive what is the right type to buy? Want to have some on hand before I open my S3 up.
jnorr - Reply Share
If my screen freezing exactly half, can that be the connection cable damaged.? It's look like it happens every time I touch or hold the corner where the volume and power buttons are. Never dropped it.
Lena Clark - Reply Share
I also have the same issue
How your issue was resolved.
Ashwin - Reply Share
Past 24 Hours: 5
Past 7 Days: 33
Past 30 Days: 119
All Time: 30,560
