Samsung Galaxy Tab S3 Battery Replacement
    1. Samsung Galaxy Tab S3  Battery Replacement, Display: step 1, image 1 of 1
      • To soften the adhesive holding the tablet together, heat up the edges of the glass panel using a heated iOpener on the edge of the device. Alternatively you can use a heat gun to loosen the adhesive.
      • Leave the iOpener on edge for two minutes.
      • Be careful not to burn yourself while handling the hot iOpener. For more information on the iOpener, use the iOpener Instructions Guide.
      Ask FixBot
    2. Samsung Galaxy Tab S3  Battery Replacement: step 2, image 1 of 1
      • Place a suction cup near edge that you heated up with the iOpener.
      • Press down on the suction cup to create a seal, and pull up with force to create a separation between the display and the midframe.
      • Use an opening tool to split apart the glass panel from the midframe.
      • Be careful to not break the glass when prying from the frame.
      Ask FixBot
    3. Samsung Galaxy Tab S3  Battery Replacement: step 3, image 1 of 1
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • As you continue along the edge using the opening tool, use a plastic card to keep the glass separate from the midframe.
      • You can also use multiple opening picks instead of a plastic card.
      Ask FixBot
    4. Samsung Galaxy Tab S3  Battery Replacement: step 4, image 1 of 3 Samsung Galaxy Tab S3  Battery Replacement: step 4, image 2 of 3 Samsung Galaxy Tab S3  Battery Replacement: step 4, image 3 of 3
      • Pull off the glass panel using the suction cup.
      • As you remove the glass panel, be careful not to tear the ribbon connecting the motherboard to the display.
      • Carefully disconnect the ribbon cable connecting the display assembly to the motherboard. You can disconnect this ribbon from either end.
      Ask FixBot
    5. Samsung Galaxy Tab S3  Battery Replacement, Rear glass panel: step 5, image 1 of 2 Samsung Galaxy Tab S3  Battery Replacement, Rear glass panel: step 5, image 2 of 2
      • Repeat steps 3 through 7 to remove the rear glass panel on the opposite side of the device.
      Ask FixBot
    1. Samsung Galaxy Tab S3  Battery Replacement, Battery: step 6, image 1 of 2 Samsung Galaxy Tab S3  Battery Replacement, Battery: step 6, image 2 of 2
      • Use a Phillips #000 screwdriver to unscrew the five screws securing the battery, and the twenty-two screws surrounding the midframe.
      Ask FixBot
    2. Samsung Galaxy Tab S3  Battery Replacement: step 7, image 1 of 1
      • The midframe should snap off from the device’s motherboard.
      Ask FixBot
    3. Samsung Galaxy Tab S3  Battery Replacement: step 8, image 1 of 3 Samsung Galaxy Tab S3  Battery Replacement: step 8, image 2 of 3 Samsung Galaxy Tab S3  Battery Replacement: step 8, image 3 of 3
      • Locate the ribbon running from the midframe and disconnect it from the motherboard with the flat end of a spudger.
      Ask FixBot
    4. Samsung Galaxy Tab S3  Battery Replacement: step 9, image 1 of 2 Samsung Galaxy Tab S3  Battery Replacement: step 9, image 2 of 2
      • Use the flat end of the spudger to pop off the connector between the battery and the motherboard.
      Ask FixBot
    5. Samsung Galaxy Tab S3  Battery Replacement: step 10, image 1 of 2 Samsung Galaxy Tab S3  Battery Replacement: step 10, image 2 of 2
      • Flip the midframe over and pop the battery out, making sure to slide it out from underneath the ribbon cables.
      Ask FixBot
    6. Samsung Galaxy Tab S3  Battery Replacement: step 11, image 1 of 1
      • The battery should now be removed and detached from the device.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. If you have removed too much adhesive, you may need to apply more during the reassembly process.
9 other people completed this guide.
Mimi Rose
684 Reputation
4 Guides authored
Cal Poly, Team S22-G4, Maness Spring 2018 Member of Cal Poly, Team S22-G4, Maness Spring 2018
CPSU-MANESS-S18S22G4
5 Members
60 Guides authored
7 Guide Comments
This repair can be done without removing the screen!
hansderaedt - Reply Share
how? would it be simpler to do it that way?
Ryan McDaniel - Reply Share
There is no reason to remove the screen. It’s super risky to do it that way. When you take the battery out, just use some alcohol on the sides of the battery to weaken the adhesive and use a suction cup to pull the battery out. No need to push on it from the screen side.
Nick Youngstrom - Reply Share
What I get for reading a guide before checking comment, TOTALLY unnecessary step in removing screen. LCD cost $220 on ebay….
Phenix City - Reply Share
Un vrai tuto de merde avec lequel vous êtes assuré de niquer votre tablette !!! Je vous recommande expressément de rechercher sur youtube “ How to Replace Your Samsung Galaxy Tab S3 SM-T825 Battery “ pour trouver un VRAI TUTO simple et qui vous évitera à coup sur de flinguer votre écran.
P de Rochefort
psurbook - Reply Share
Past 24 Hours: 10
Past 7 Days: 43
Past 30 Days: 160
All Time: 28,517
