Samsung Galaxy Tab A9 Plus Screen Replacement
    1. Samsung Galaxy Tab A9 Plus Screen Replacement, Screen: step 1, image 1 of 3 Samsung Galaxy Tab A9 Plus Screen Replacement, Screen: step 1, image 2 of 3 Samsung Galaxy Tab A9 Plus Screen Replacement, Screen: step 1, image 3 of 3
      • Power the device off by holding the power button for 10-15 seconds.
      • Use the heat gun to evenly heat the edge of the device and loosen the adhesive securing the screen to the tablet.
      • The heat gun should be set on 5 when using it to heat the adhesive.
      • Be careful when using the heat gun; it can damage the device if you heat one area too much or for too long.
      • Use the suction tool to separate the screen from the case, and insert an opening pick to help keep the screen edge separated from the rest of the device.
      • Slide a second pick around the edge to cut through the remaining glue of the screen.
      • Continue placing plastic opening picks in the gaps about every inch or so intill the screen fully separates.
      Ask FixBot
    2. Samsung Galaxy Tab A9 Plus Screen Replacement: step 2, image 1 of 2 Samsung Galaxy Tab A9 Plus Screen Replacement: step 2, image 2 of 2
      • Gently lift the screen towards the top of the device (the side with the front camera), being careful not to damage the orange flex cable.
      • Use a JIS #00 screwdriver to remove two 2.4 mm screws securing the metal bracket.
      • Remove the metal bracket covering the connector and place it to the side to use for reassembly.
      Ask FixBot
    3. Samsung Galaxy Tab A9 Plus Screen Replacement: step 3, image 1 of 2 Samsung Galaxy Tab A9 Plus Screen Replacement: step 3, image 2 of 2
      • Make sure to disconnect the battery from the main board. (Black connector under the spudger). I've had a screen die from not doing this.
      • Carefully slide a spudger or opening pick under the glued-down cable to separate its adhesive and disconnect the cable.
      • Remove the display screen from the tablet.
      Ask FixBot
    4. Samsung Galaxy Tab A9 Plus Screen Replacement: step 4, image 1 of 1
      • Use a spudger to remove any excess adhesive remaining on the edges of the device's rear housing.
      • If you are having trouble removing the adhesive, try using adhesive remover.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
5 other people completed this guide.
0 Guide Comments
Past 24 Hours: 27
Past 7 Days: 200
Past 30 Days: 833
All Time: 5,934
