Introduction
If the front camera of your Samsung Galaxy Tab A8 doesn't seem to be functioning properly, use this guide to replace the camera. Before doing so, be sure to troubleshoot your camera to eliminate any other causes and also possibly remove the need for replacement.
The front camera is a nice accessory for taking photographs of yourself and similar shots. It's what most would call a "selfie". :)
The camera may become unresponsive due to lag, battery failure, or software issues. It can also cease to function completely if sufficiently damaged, scratched, or waterlogged. It may also simply be blurry due to contaminants such as fingerprints. Make sure to clean your camera and update your software before attempting replacement. If these issues continue to persist, then the following steps will guide you in replacing your front camera.
Fully power off the device.
Orient the screen so it is face-up.
Apply anti-clamp or other suction device to apply constant upward force on the screen.
Heat the screen to soften the adhesive with a heat gun or blow dryer. Be sure to heat all sides as evenly as possible.
Use plastic opening picks, or a Jimmy if necessary, to remove the adhesive and get under the screen.
Using the plastic opening picks, move around the screen slowly, one corner at a time. Every few inches, leave an additional opening pick behind where you are working to hold the screen open while continuing to remove the adhesive.
Remove the four 1.8mm screws using a Phillips #000 screwdriver.
Remove the bracket to gain access to the front camera.
