Samsung Galaxy Tab A (2019) Screen Replacement
Video Instructions
26 other people completed this guide.
Nick Myers
5,809 Reputation
33 Guides authored
10 Guide Comments
si on a pas conserver le pcb qu’il enlève de l’écran cassé on peux le racheter ou?
Yacine Chennoufi - Reply Share
How do you heat up the screen to loosen the glue? Heat gun? Blow dryer? How do you keep from damaging it from getting too hot? Thanks :)
Justin Shields - Reply Share
Use a heat gun it will help that’s what I would do
nicholaswiding - Reply Share
I tried this with a hairdryer. While there are probably options that work better, it still helped a lot. I am too much of a coward to use a heat gun, as I don't want to fry it, so I used my wifes hair dryer to the point where the tablet was very hot to the touch around the edge of the screen.
Kristian Jarmund - Reply Share
Best and safest way to heat up a device to remove screen is with a heating mat………. i set mine at 75deg
Alan Sears - Reply Share
Past 24 Hours: 12
Past 7 Days: 69
Past 30 Days: 273
All Time: 20,124
