Samsung Galaxy Tab 7.0 Front Panel Replacement
  1. Samsung Galaxy Tab 7.0 Front Panel Replacement, Front Panel: step 1, image 1 of 1
    • Use the flat end of a metal spudger to pry the two plastic tabs near the dock connector off the rear case.
  2. Samsung Galaxy Tab 7.0 Front Panel Replacement: step 2, image 1 of 1
    • Remove the two 4.1 mm Tri-Wing screws near the adjacent edges of the dock connector.
  3. Samsung Galaxy Tab 7.0 Front Panel Replacement: step 3, image 1 of 1
    • The following steps will require you to disengage several clips (highlighted in red) around the perimeter of the rear case. The clips are delicate and fragile; proceed with caution.
  4. Samsung Galaxy Tab 7.0 Front Panel Replacement: step 4, image 1 of 2 Samsung Galaxy Tab 7.0 Front Panel Replacement: step 4, image 2 of 2
    • Disclaimer: The Galaxy Tab we acquired already had a shattered front glass panel. However, the procedure outlined in this guide is identical for both intact/shattered front panels.
    • Insert a plastic opening tool near the bottom left edge of the rear case.
    • Use your plastic opening tool to gently create a small gap between the front panel and the rear panel near the bottom left edge.
    • Run the plastic opening tool along the left side of the perimeter to create a bigger gap between the front panel and the rear panel.
    • Insert two guitar picks into the small gap created by the plastic opening tool.
  5. Samsung Galaxy Tab 7.0 Front Panel Replacement: step 5, image 1 of 2 Samsung Galaxy Tab 7.0 Front Panel Replacement: step 5, image 2 of 2
    • Insert the plastic opening tool into the dock connector and wedge it underneath the front panel/motherboard assembly.
    • Thrust the plastic opening tool downwards to create a gap near the lower left corner of the front panel assembly.
    • Insert a guitar pick into the newly created gap near the lower left edge of the Galaxy Tab.
  6. Samsung Galaxy Tab 7.0 Front Panel Replacement: step 6, image 1 of 3 Samsung Galaxy Tab 7.0 Front Panel Replacement: step 6, image 2 of 3 Samsung Galaxy Tab 7.0 Front Panel Replacement: step 6, image 3 of 3
    • Be careful when approaching the top left corner of the Galaxy Tab. Be sure to follow the next step carefully.
    • When separating the front panel from the top left corner of the Galaxy Tab, be careful not to rip the microphone ribbon cable (highlighted in red in the first picture). It is extremely thin and easy to tear.
    • Insert a plastic opening tool into the gap next to the left side of the guitar pick.
    • Make sure to wedge it underneath the inner framework to gain the most leverage when releasing the clips.
    • Simultaneously lift upwards and run the plastic opening tool along the top left corner of the Galaxy Tab to free the Front Panel Assembly from the retaining clips.
  7. Samsung Galaxy Tab 7.0 Front Panel Replacement: step 7, image 1 of 1
    • Slightly lift the left side of the front panel assembly to separate it from its housing within the rear panel.
    • Do not completely lift the front panel assembly, as it is still restrained to the rear panel by clips around the top, bottom, and right sides. Doing so may cause severe damage.
  8. Samsung Galaxy Tab 7.0 Front Panel Replacement: step 8, image 1 of 2 Samsung Galaxy Tab 7.0 Front Panel Replacement: step 8, image 2 of 2
    • Wedge the flat edge of an opening tool between the front panel and rear panel near the dock connector.
    • Use a plastic opening tool to pry the bottom right corner out of its housing in the rear panel.
  9. Samsung Galaxy Tab 7.0 Front Panel Replacement: step 9, image 1 of 1
    • Lift and remove the front panel assembly from the rear panel.
27 other people completed this guide.
1 Guide Comment
Guide is incomplete. We all want to see how to replace the front glass that is shattered. This is not a simple process and would make this guide more complete.
luffman - Reply Share
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 33
All Time: 38,537
