Samsung Galaxy Tab 4 Motherboard Replacement
    1. Samsung Galaxy Tab 4 Motherboard Replacement, Motherboard: step 1, image 1 of 2 Samsung Galaxy Tab 4 Motherboard Replacement, Motherboard: step 1, image 2 of 2
      • Insert the plastic opening tool into the gap between the device frame and the back panel on any side of the device.
      • Slide the opening tool around the edges of the device to disconnect the back panel from the frame.
      Ask FixBot
    2. Samsung Galaxy Tab 4 Motherboard Replacement: step 2, image 1 of 3 Samsung Galaxy Tab 4 Motherboard Replacement: step 2, image 2 of 3 Samsung Galaxy Tab 4 Motherboard Replacement: step 2, image 3 of 3
      • Carefully remove the back panel from the frame of the device.
      Ask FixBot
    3. Samsung Galaxy Tab 4 Motherboard Replacement: step 3, image 1 of 3 Samsung Galaxy Tab 4 Motherboard Replacement: step 3, image 2 of 3 Samsung Galaxy Tab 4 Motherboard Replacement: step 3, image 3 of 3
      • Using a Phillips #00 Screwdriver, remove the five 4 mm screws connecting the motherboard to the frame of the device.
      Ask FixBot
    4. Samsung Galaxy Tab 4 Motherboard Replacement: step 4, image 1 of 3 Samsung Galaxy Tab 4 Motherboard Replacement: step 4, image 2 of 3 Samsung Galaxy Tab 4 Motherboard Replacement: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Use the plastic opening tool to unlock the battery wire from the motherboard by flipping-up the small retaining flap.
      • Use the tweezers to carefully remove the battery wire from the motherboard by pulling it away from the retainer flap.
      Ask FixBot
    5. Samsung Galaxy Tab 4 Motherboard Replacement: step 5, image 1 of 3 Samsung Galaxy Tab 4 Motherboard Replacement: step 5, image 2 of 3 Samsung Galaxy Tab 4 Motherboard Replacement: step 5, image 3 of 3
      • Use the plastic opening tool to unlock the wire on the narrow section of the motherboard by flipping-up the retaining flap.
      • Use the tweezers to carefully remove the wire from the motherboard by sliding it away from the retaining flap.
      Ask FixBot
    6. Samsung Galaxy Tab 4 Motherboard Replacement: step 6, image 1 of 3 Samsung Galaxy Tab 4 Motherboard Replacement: step 6, image 2 of 3 Samsung Galaxy Tab 4 Motherboard Replacement: step 6, image 3 of 3
      • Disconnect the wire near the bottom of the motherboard by placing the plastic opening tool under the edge of the connector to flip it up.
      Ask FixBot
    7. Samsung Galaxy Tab 4 Motherboard Replacement: step 7, image 1 of 3 Samsung Galaxy Tab 4 Motherboard Replacement: step 7, image 2 of 3 Samsung Galaxy Tab 4 Motherboard Replacement: step 7, image 3 of 3
      • Disconnect the wire near the top of the motherboard by placing the plastic opening tool under the edge of the connector to flip it up.
      Ask FixBot
    8. Samsung Galaxy Tab 4 Motherboard Replacement: step 8, image 1 of 3 Samsung Galaxy Tab 4 Motherboard Replacement: step 8, image 2 of 3 Samsung Galaxy Tab 4 Motherboard Replacement: step 8, image 3 of 3
      • Gently remove the motherboard from the frame of the device by grabbing the top and bottom ends and pulling it toward you.
      • Several plastic tabs keep the motherboard in place, so you will have to apply some force.
      Ask FixBot
3 other people completed this guide.
Peter Oliver
227 Reputation
1 Guide authored
Cal Poly, Team 18-3, Forte Fall 2016 Member of Cal Poly, Team 18-3, Forte Fall 2016
CPSU-FORTE-F16S18G3
4 Members
45 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 37
All Time: 2,261
