Samsung Galaxy Tab 10.1 Battery Replacement
  1. Samsung Galaxy Tab 10.1 Battery Replacement, Rear Panel: step 1, image 1 of 2 Samsung Galaxy Tab 10.1 Battery Replacement, Rear Panel: step 1, image 2 of 2
    Tool used on this step:
    Buy
    • Place the bottom of the tablet towards you.
    • Remove the 4.1mm screws near the charge port with a Tri-Wing screwdriver.
    • If there are plastic tabs covering these screws, use pointed tweezers to pry the tabs out.
    • On model GT-P7500, this step is omitted, as that model doesn't have these 2 screws.
  2. Samsung Galaxy Tab 10.1 Battery Replacement: step 2, image 1 of 3 Samsung Galaxy Tab 10.1 Battery Replacement: step 2, image 2 of 3 Samsung Galaxy Tab 10.1 Battery Replacement: step 2, image 3 of 3
    • Start in the middle of the left side and insert a plastic opening tool between the rear panel and the front panel assembly.
    • Carefully run the plastic opening tool along the left and top edge to pry the rear panel away from the rest of the device.
    • Place opening picks along the side you have already pried open to keep the back panel detached from the rest of the device.
    • Be sure to work carefully, as prying too firmly can crack the screen.
  3. Samsung Galaxy Tab 10.1 Battery Replacement: step 3, image 1 of 3 Samsung Galaxy Tab 10.1 Battery Replacement: step 3, image 2 of 3 Samsung Galaxy Tab 10.1 Battery Replacement: step 3, image 3 of 3
    • Using the plastic opening tools, continue to carefully run along the right and bottom edge, and then lift the screen from the back panel.
  4. Samsung Galaxy Tab 10.1 Battery Replacement, Battery: step 4, image 1 of 3 Samsung Galaxy Tab 10.1 Battery Replacement, Battery: step 4, image 2 of 3 Samsung Galaxy Tab 10.1 Battery Replacement, Battery: step 4, image 3 of 3
    • Flip up the retaining flaps on the ZIF connectors that secure the three large ribbon cables.
    • Carefully pull the three ribbon cables from their sockets on the motherboard.
  5. Samsung Galaxy Tab 10.1 Battery Replacement: step 5, image 1 of 2 Samsung Galaxy Tab 10.1 Battery Replacement: step 5, image 2 of 2
    • Remove the ten 3 mm Phillips #00 screws surrounding the battery.
  6. Samsung Galaxy Tab 10.1 Battery Replacement: step 6, image 1 of 3 Samsung Galaxy Tab 10.1 Battery Replacement: step 6, image 2 of 3 Samsung Galaxy Tab 10.1 Battery Replacement: step 6, image 3 of 3
    • Lift the edge of the battery up with your finger or a spudger.
    • Detach the battery by holding the motherboard down while gently lifting the battery up.
61 other people completed this guide.
Jess McCafferty
1,704 Reputation
2 Guides authored
Cal Poly, Team 13-5, Forte Fall 2013 Member of Cal Poly, Team 13-5, Forte Fall 2013
CPSU-FORTE-F13S13G5
5 Members
17 Guides authored
20 Guide Comments
Those 3 plastic bands with connectors at the end are a really poor design and a drag to put back on correctly : there's a little white line drawn on each one that needs to be aligned with a line drawn on the socket itself. This means you really have to push them back in (with a little platic tool for example). If not you can have a non functioning screen or no touch detection.
zen - Reply Share
What if your stupid aunt is trying to open it and you can open it but she said that you broke it? What can I do about it. Ppl. HM
Isabella - Reply Share
What would be the correct battery that is suitable for the Tab proT520? I can't find any reference to this particular models battery..
Tomjonkins - Reply Share
good jobs man
corentin bouyssou - Reply Share
Nice tutorials, thank you! I want to ask you about exactly battery. Where is it better to order it/ I mean, if i order it online? I live in Europe and know some stores of hardware, such as hardware.nu and so on but also i know such stores as Amazon and eBay also Aliexpress..Tell me where is quaity is the best?
Scott Waschlerner - Reply Share
Past 24 Hours: 5
Past 7 Days: 31
Past 30 Days: 140
All Time: 363,338
