Samsung Galaxy Sol Rear Camera Replacement
    1. Samsung Galaxy Sol Rear Camera Replacement, Battery: step 1, image 1 of 1
      • Remove the back case of the phone by using an opening tool or fingernail to lift the divot on the top left side.
      Ask FixBot
    2. Samsung Galaxy Sol Rear Camera Replacement: step 2, image 1 of 1
      • Remove the battery by lifting from the bottom up with an opening tool or a small flat tool such as a credit card.
      Ask FixBot
    1. Samsung Galaxy Sol Rear Camera Replacement, Rear Camera: step 3, image 1 of 1
      • Remove the grey back of the phone by unscrewing all ten 0.4mm screws with a Phillips #00 screw bit.
      Ask FixBot
    2. Samsung Galaxy Sol Rear Camera Replacement: step 4, image 1 of 1
      • After you have removed all the screws, take a credit card or plastic tool to lift the screen. You will go all around the border of the phone.
      Ask FixBot
    3. Samsung Galaxy Sol Rear Camera Replacement: step 5, image 1 of 3 Samsung Galaxy Sol Rear Camera Replacement: step 5, image 2 of 3 Samsung Galaxy Sol Rear Camera Replacement: step 5, image 3 of 3
      • After removing the grey part of the phone, you will need to remove the motherboard by detaching all the chips.
      Ask FixBot
    4. Samsung Galaxy Sol Rear Camera Replacement: step 6, image 1 of 1
      • Once you detach the chips, remove the hard drive to access the rear camera.
      Ask FixBot
    5. Samsung Galaxy Sol Rear Camera Replacement: step 7, image 1 of 2 Samsung Galaxy Sol Rear Camera Replacement: step 7, image 2 of 2
      • To remove the rear camera, flip the tab upward and then pull the camera straight out.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 60
All Time: 849
