Introduction
Use this guide to remove the rear glass of the Samsung Galaxy S9.
Opening the Samsung Galaxy S9 will damage the waterproof sealing on the device. If you do not replace the adhesive seals, your phone will function normally, but will loose its water-protection.
You’ll need replacement adhesive to reattach components when reassembling the device.
Before you begin, switch off your phone.
Apply a heated iOpener to a long edge of the phone to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes.
Press a suction cup onto the back cover.
Lift the back cover's bottom edge with your suction cup, opening a slight gap between the back cover and the frame.
Insert an opening pick in the gap you created and slide it to the bottom right corner.
Insert a second opening pick and slide it to the bottom left corner.
Insert a third opening pick to prevent the adhesive from resealing during the rest of the removal procedure.
Secure the new back cover with pre-cut adhesive or double-sided adhesive tape.
After installing the rear cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
After you've completed the repair, follow this guide to test your repair.
14 other people completed this guide.
2 Guide Comments
Sollte nach Abschluss der Reparatur der Fingerabdrucksensor nicht funktionieren bitte folgende Schritte machen:
1. Schalte das Handy aus und hänge es ein Ladegerät
2. Starte das Handy im Restore Modus indem du die Bixby, Lauter und Powertaste gleichzeitig drückst bis das Samsung Logo kommt.
3. Wähle in dem Menü den Punkt: Wipe Cache Partition aus und bestätige mit Power deine Auswahl.
4. Starte das Gerät neu.
Hi,
At least on my unit, the fingerprint sensor was actually retained in the back of the unit and came loose from the camera lens assembly during back cover removal, so I did not need to undo the connector for it until after I had removed the back cover. I was kind of worried when this happened since I thought I tore the cable at first. May want to note that buying a new fingerprint sensor adhesive piece is a good idea, it's like 3 bucks on here.
Also, this might just be me but I would really have preferred more reinstallation details other than "hey reverse these instructions". The aftermarket rear covers on here do not come with the adhesive all preinstalled, only a few pieces of it, so you have to carefully check and make sure you put those on and alignment isn't easy to figure out if you don't know what you're doing. I did alright on that part, but the back cover I bought has adhesive that's too thin and didn't seal everywhere so I will have to redo that and the fingerprint sensor adhesive next weekend.
