Samsung Galaxy S9 Battery Replacement
    1. Samsung Galaxy S9 Battery Replacement, Rear Glass Removal: step 1, image 1 of 1
      • Before you begin, switch off your phone.
      • Apply a heated iOpener to a long edge of the phone to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes.
      • You might need to reheat and reapply the iOpener several times during the removal procedure to get the adhesive warm enough to cut. Follow the iOpener instructions to avoid overheating.
      • The adhesive of the Samsung Galaxy S9 is very strong. A hair dryer, heat gun, or hot plate may also be used if you aren't able to open the device with the iOpener. Be careful not to overheat the phone—the AMOLED display and internal battery are both susceptible to heat damage.
      Ask FixBot
    2. Samsung Galaxy S9 Battery Replacement: step 2, image 1 of 1
      • In the following steps, you'll be cutting through the adhesive securing the back cover.
      • The adhesive in the inside of the back cover is laid out as seen in the image.
      • You'll be slicing through the adhesive in the areas shown:
      • Thick portions of adhesive
      • Thin areas of adhesive
      • Avoid prying or slicing in this area, to protect the fingerprint sensor flex cable.
      Ask FixBot
    3. Samsung Galaxy S9 Battery Replacement: step 3, image 1 of 3 Samsung Galaxy S9 Battery Replacement: step 3, image 2 of 3 Samsung Galaxy S9 Battery Replacement: step 3, image 3 of 3
      • If the phone's rear glass is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
      • Press a suction cup onto the back cover.
      • Lift the back cover's bottom edge with your suction cup, opening a slight gap between the back cover and the frame.
      • This may require a significant amount of force, but you only need to open a very slight gap with the suction cup to insert your tool. If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools very fast, so you may need to heat it repeatedly.
      • Insert an opening pick in the gap you created and slide it to the bottom right corner.
      • Insert a second opening pick and slide it to the bottom left corner.
      • Insert a third opening pick to prevent the adhesive from resealing during the rest of the removal procedure.
      Ask FixBot
    4. Samsung Galaxy S9 Battery Replacement: step 4, image 1 of 2 Samsung Galaxy S9 Battery Replacement: step 4, image 2 of 2
      • While inserting only the tip of the opening pick, slide it from the bottom left corner along the side to the top.
      • Slide the pick around the top corner and leave it there to prevent the adhesive from resealing.
      Ask FixBot
    5. Samsung Galaxy S9 Battery Replacement: step 5, image 1 of 3 Samsung Galaxy S9 Battery Replacement: step 5, image 2 of 3 Samsung Galaxy S9 Battery Replacement: step 5, image 3 of 3
      • Slide the opening pick from the bottom right corner along the side to the top.
      • Apply more heat if the adhesive becomes hard to cut. During the removal process, the back cover is under tension all the time and is likely to break if the adhesive isn't softened enough.
      • Slide the opening pick around the corner and cut the remaining adhesive at the top of the phone.
      • Don't open the phone all the way yet. The fragile fingerprint sensor cable still connects the back cover to the motherboard.
      Ask FixBot
    6. Samsung Galaxy S9 Battery Replacement: step 6, image 1 of 2 Samsung Galaxy S9 Battery Replacement: step 6, image 2 of 2
      • Carefully lift the side of the rear glass where the volume button is located.
      • Use the edge of a spudger to pry up and disconnect the fingerprint sensor flex cable.
      Ask FixBot
    7. Samsung Galaxy S9 Battery Replacement: step 7, image 1 of 1
      • Remove the rear glass.
      • When reassembling follow this guide to replace the adhesive and reinstall the rear glass.
      • In case you want to replace your rear glass follow this guide to transfer the rear camera bezel including the fingerprint.
      Ask FixBot
    1. Samsung Galaxy S9 Battery Replacement, NFC Antenna and Charging Coil: step 8, image 1 of 1
      • Remove the eight 4 mm Phillips #00 screws.
      Ask FixBot
    2. Samsung Galaxy S9 Battery Replacement: step 9, image 1 of 2 Samsung Galaxy S9 Battery Replacement: step 9, image 2 of 2
      • Insert an opening pick under the right side of the plastic cover containing the NFC antenna and charging coil.
      • Twist or pry to release the plastic clips securing the cover.
      Ask FixBot
    3. Samsung Galaxy S9 Battery Replacement: step 10, image 1 of 2 Samsung Galaxy S9 Battery Replacement: step 10, image 2 of 2
      • Insert an opening pick under the left side of the plastic cover.
      Ask FixBot
    4. Samsung Galaxy S9 Battery Replacement: step 11, image 1 of 1
      • Remove the plastic cover containing the NFC antenna and charging coil.
      Ask FixBot
    1. Samsung Galaxy S9 Battery Replacement, Battery Disconnection: step 12, image 1 of 1
      • Use the flat end of a spudger to pry up and disconnect the battery flex cable.
      Ask FixBot
    1. Samsung Galaxy S9 Battery Replacement, Battery: step 13, image 1 of 2 Samsung Galaxy S9 Battery Replacement, Battery: step 13, image 2 of 2
      • Use an iOpener to loosen the adhesive beneath the battery. Apply the iOpener for at least two minutes.
      • In the following step, only apply the spudger in the areas marked in green, which is where the battery adhesive is located.
      • Avoid this area. There's a gap in the mid-frame right below the battery, and you can accidentally damage the display through it.
      Ask FixBot
    2. Samsung Galaxy S9 Battery Replacement: step 14, image 1 of 2 Samsung Galaxy S9 Battery Replacement: step 14, image 2 of 2
      • If you have trouble prying up the battery, you can apply 1-2 drops of high-concentration (>90%) isopropyl alcohol under each corner of the battery and allow it to penetrate for several minutes to help weaken the adhesive.
      • Try your best not to deform the battery during the following removal process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools.
      • Insert the flat end of a spudger at the top left corner of the battery where the flex cable is located and start to pry it up using firm, constant pressure.
      • Work your way down the left side of the battery and loosen the adhesive with the spudger.
      Ask FixBot
    3. Samsung Galaxy S9 Battery Replacement: step 15, image 1 of 1
      • Insert the spudger at the top right corner of the battery and pry it up.
      Ask FixBot
    4. Samsung Galaxy S9 Battery Replacement: step 16, image 1 of 1
      • Remove the battery.
      • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
      • If you used isopropyl alcohol, wait ten minutes before installing the new battery to allow the alcohol to completely evaporate.
      • To install a new battery and adhesive, follow this guide.
      Ask FixBot
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
For optimal performance, calibrate your newly installed battery after completing this guide.
102 other people completed this guide.
Dominik Schnabelrauch
266,039 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
27 Guide Comments
An exceptionally useful, and dare I add - well-written - fixit.
Doug Davis - Reply Share
Merci ifixit.
Mais je n ais pas compris la deconnection du NFC, es une nappe. Je ne comprends pas.
Di Da - Reply Share
Bonjour @Di Da, vous trouverez la partie qui parle de la démontage du coque / de la cache en plastique qui abrite l'antenne NFC et la bobine de recharge dans les étapes 9 à 11. Au fait, la cache en plastique et la nappe sont UNE pièce ensemble, on ne peut pas les séparer et dès que vous démontez la cache, la nappe va elle aussi sortir automatiquement. Elle n’est lié que par quelques contacts, vous n’avez pas besoin de déconnecter ceux-ci, ils se séparent automatiquement quand vous retirez la coque.
Sandra Hiller - Reply Share
Wenn nach Abschluss der Reparatur der Fingerabdrucksensor nicht funktioniert muss man in den Restore Modus des Handy gehen.
Dazu das Smartphone an den Lader hängen und das Gerät ausschalten.
Dannach die Bixby + Power + Lauter Taste gedrückt halten bis das Samsung Logo erscheint.
In dem Menü den Punkt “Wipe Cache Partition” auswählen mit Lauter / Leiser und mit Power die Auswahl bestätigen.
Die Auswahl nochmal mit Yes bestätigen und warten bis das Gerät die Cache Partition gelöscht hat und das Gerät neu starten.
Dannach sollte der Fingerabdrucksensor wie gewohnt funktionieren.
Sebastian Coenen - Reply Share
Why does the guide stop? How am I supposed to use the adhesive??
Mitchell steindler - Reply Share
Past 24 Hours: 39
Past 7 Days: 238
Past 30 Days: 1,053
All Time: 296,083
