Samsung Galaxy S8 Plus Motherboard Replacement
      • Step by step tutorial about dismantling the logic board from Galaxy S8+. If you need more information ask them in the comments!
      Ask FixBot
7 other people completed this guide.
Alex Sander
39,438 Reputation
201 Guides authored
4 Guide Comments
How do you then fix the imei to match the back of the phone and to work with the plan it was on when broken; having to register/activate a new device for a motherboard repair is bull$][!+, and doesn't take care of the problem for the customer.
chrisjwellnitz - Reply Share
Hello, The connector from the battery to the motherboard has been damaged. Due to water getting in there’s been corrosion on the connectors which has eaten away on 2 of the capacitors there down to the silicon. Is there anyway to fix this? Perhaps any way to add material back or make some kind of jumper? I doubt I can get a replacement motherboard, but if you know if this can be done that would be great.
Ggarcia - Reply Share
..does this correct a problem with the SIM card holder or is that a separate board in the phone?
Sigmund -
Sigmund - Reply Share
My phone it shows like a shock sometimes when I plunge it on charger or when I start a mobile data or when I unlock it
YOHANA YOHANA - Reply Share
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 55
All Time: 12,808
