Samsung Galaxy S8 Plus Display Adhesive Replacement
    1. Samsung Galaxy S8 Plus Display Adhesive Replacement, Display Adhesive: step 1, image 1 of 3 Samsung Galaxy S8 Plus Display Adhesive Replacement, Display Adhesive: step 1, image 2 of 3 Samsung Galaxy S8 Plus Display Adhesive Replacement, Display Adhesive: step 1, image 3 of 3
      • Remove all traces of adhesive and debris from the phone's frame. Clean the adhesion surface with high concentration isopropyl alcohol (over 90%) and wipe it clean with a lint-free cloth.
      • If glue or glass remnants are left behind, the new display will not mount correctly and may be damaged.
      • Lay the adhesive strips out to get an idea of where they go.
      • Peel off the clear plastic backing from the large pre-cut adhesive strip, exposing one side of adhesive.
      Ask FixBot
    2. Samsung Galaxy S8 Plus Display Adhesive Replacement: step 2, image 1 of 3 Samsung Galaxy S8 Plus Display Adhesive Replacement: step 2, image 2 of 3 Samsung Galaxy S8 Plus Display Adhesive Replacement: step 2, image 3 of 3
      • Carefully line up a long edge of the adhesive with the edge of the phone frame.
      • Make sure that the adhesive cutouts match the phone's.
      • Set the adhesive down lightly on the frame.
      • If it is not properly aligned, carefully peel the adhesive back up.
      • Once the adhesive is aligned, use your fingers to press the adhesive onto the frame.
      Ask FixBot
    3. Samsung Galaxy S8 Plus Display Adhesive Replacement: step 3, image 1 of 3 Samsung Galaxy S8 Plus Display Adhesive Replacement: step 3, image 2 of 3 Samsung Galaxy S8 Plus Display Adhesive Replacement: step 3, image 3 of 3
      • Peel one of the end adhesive strips from the clear plastic backing.
      • The strips are cut for a specific end and are not interchangeable.
      • Hold the strip by the two green end tabs and line the adhesive strip with the phone frame.
      • Lay the adhesive down lightly on the phone. Make sure that all cutouts are properly aligned.
      • Once aligned, use your fingers to press the adhesive into place.
      • Repeat the procedure for the remaining adhesive strip.
      Ask FixBot
    4. Samsung Galaxy S8 Plus Display Adhesive Replacement: step 4, image 1 of 1
      • Continue reassembling your device until you are ready to attach the screen.
      • If possible, test your screen's functionality before sticking it in place.
      • Peel and remove the green plastic liner from all adhesive strips to expose the screen-facing adhesive.
      • Align and set the phone screen on top of the adhesive.
      • Use your fingers to squeeze around the perimeter of the phone to set the adhesive.
      • Apply a few books worth of weight on top of the screen for an hour to help the adhesive bond.
      Ask FixBot
Follow this link to return to the Galaxy S8+ screen replacement guide.
10 other people completed this guide.
Arthur Shi
346,367 Reputation
923 Guides authored
iFixit Member of iFixit
Staff
123 Members
83,560 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 71
All Time: 7,540
