Samsung Galaxy S8 Active Camera Glass Replacement
    1. Samsung Galaxy S8 Active Camera Glass Replacement, Camera Glass: step 1, image 1 of 1
      • Lay phone face down and remove any coverings to the camera area. This way there are no obstructions to the repair area.
      Ask FixBot
    2. Samsung Galaxy S8 Active Camera Glass Replacement: step 2, image 1 of 1
      • Turn on the heat gun and hold it 3-4 inches from the glass for 5 seconds, waving it gently over the area to evenly distribute heat.
      • It may be helpful to keep the case on during this step, to avoid excessively heating the adhesive of the back panel.
      Ask FixBot
    3. Samsung Galaxy S8 Active Camera Glass Replacement: step 3, image 1 of 2 Samsung Galaxy S8 Active Camera Glass Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Gently remove the glass with tweezers.
      • If the adhesive is still strong, utilize the heat gun for another 3-5 seconds, waving it over the area.
      Ask FixBot
    4. Samsung Galaxy S8 Active Camera Glass Replacement: step 4, image 1 of 1
      • Check the surface for any residue or broken glass from previous cover.
      Ask FixBot
    5. Samsung Galaxy S8 Active Camera Glass Replacement: step 5, image 1 of 1
      • Center the new glass over the camera lens and lower it to the phone, careful to not scratch the exposed camera lens.
      Ask FixBot
    6. Samsung Galaxy S8 Active Camera Glass Replacement: step 6, image 1 of 1
      • Press gently on the perimeter of the glass to ensure a strong bond between the glass and the phone, but not pressing hard enough to break the glass.
      Ask FixBot
The device should be in working condition after the last step. Be sure to turn on the phone and verify to see if there are any obstructions to the camera view caused by the new glass covering.
1 Guide Comment
Did you use the rear camera glass from Amazon that you've put a link to under parts? The Amazon seller has stated that it doesn't fit the Samsung S8 Active so unsure whether to purchase. Thanks
Natasha Wightman - Reply Share
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 39
All Time: 1,270
