Samsung Galaxy S7 Screen Replacement
Video Overview
    1. Samsung Galaxy S7 Screen Replacement, Rear Glass: step 1, image 1 of 1
      • Opening your phone will compromise its waterproof seals. Have replacement adhesive ready before you proceed, or take care to avoid liquid exposure if you reassemble your phone without replacing the adhesive.
      • Apply a heated iOpener to a long edge of the phone for about two minutes.
      • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the OLED display and internal battery are both susceptible to heat damage.
      Ask FixBot
    2. Samsung Galaxy S7 Screen Replacement: step 2, image 1 of 3 Samsung Galaxy S7 Screen Replacement: step 2, image 2 of 3 Samsung Galaxy S7 Screen Replacement: step 2, image 3 of 3
      • When the back panel is warm to the touch, apply a suction cup as close to the heated edge of the phone as you can while avoiding the curved edge.
      • The suction cup will not make a good seal on the curved portion of the glass.
      • If the phone's back cover is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
      • Lift on the suction cup and insert an opening pick under the rear glass.
      • The rear glass can break if you use too much force or attempt to pry with metal tools.
      • Due to the curved glass, you will be pushing up, rather than inserting parallel to the plane of the phone.
      • If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools very fast, so you may need to heat it repeatedly.
      • Optionally, once the pick is inserted, you can add a few drops of isopropyl alcohol into the gap to help weaken the adhesive in the following steps.
      Ask FixBot
    3. Samsung Galaxy S7 Screen Replacement: step 3, image 1 of 1
      • Once you have the pick firmly inserted into the glass, reheat and reapply the iOpener to soften the adhesive.
      Ask FixBot
    4. Samsung Galaxy S7 Screen Replacement: step 4, image 1 of 2 Samsung Galaxy S7 Screen Replacement: step 4, image 2 of 2
      • Slide the opening pick down along the side of the phone, separating the adhesive.
      • Go slowly so that the tip doesn't slip out of the seam. If sliding becomes difficult, reheat and reapply the iOpener.
      • Leave the pick in place and grab a second pick as you proceed to the next step. Leaving the pick inserted can help prevent the glue you just separated from re-adhering.
      Ask FixBot
    5. Samsung Galaxy S7 Screen Replacement: step 5, image 1 of 3 Samsung Galaxy S7 Screen Replacement: step 5, image 2 of 3 Samsung Galaxy S7 Screen Replacement: step 5, image 3 of 3
      • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
      • Leave an opening pick in each edge of the phone as you continue to the next to prevent the adhesive from resealing.
      Ask FixBot
    6. Samsung Galaxy S7 Screen Replacement: step 6, image 1 of 2 Samsung Galaxy S7 Screen Replacement: step 6, image 2 of 2
      • Lift the glass and remove it from the phone.
      Ask FixBot
    7. Samsung Galaxy S7 Screen Replacement: step 7, image 1 of 2 Samsung Galaxy S7 Screen Replacement: step 7, image 2 of 2
      • To reinstall the back cover with a custom-cut adhesive strip, follow this guide.
      • If you're cleaning the midframe surface with isopropyl alcohol, be careful not to get any alcohol on the wireless charging coil. The coil coating will break down if it contacts alcohol.
      • Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
      • If desired, you may reinstall the back cover without replacing the adhesive. Remove any large chunks of adhesive that might prevent the back cover from sitting down flush. After installation, heat the back cover and apply pressure to secure it. It won't be waterproof, but the glue is usually more than strong enough to hold.
      Ask FixBot
    1. Samsung Galaxy S7 Screen Replacement, NFC Antenna and Charging Coil Assembly: step 8, image 1 of 1
      • Remove the eight 3.5 mm Phillips screws securing the NFC antenna and charging coil assembly.
      Ask FixBot
    2. Samsung Galaxy S7 Screen Replacement: step 9, image 1 of 3 Samsung Galaxy S7 Screen Replacement: step 9, image 2 of 3 Samsung Galaxy S7 Screen Replacement: step 9, image 3 of 3
      • Insert the tip of a spudger into the small notch on the left side of the antenna assembly, and pry the assembly up and out of the frame.
      • Remove the antenna assembly.
      Ask FixBot
    3. Samsung Galaxy S7 Screen Replacement: step 10, image 1 of 2 Samsung Galaxy S7 Screen Replacement: step 10, image 2 of 2
      • Use the flat end of a spudger to lift the charging coil assembly out of the phone.
      Ask FixBot
    1. Samsung Galaxy S7 Screen Replacement, Battery Connector: step 11, image 1 of 2 Samsung Galaxy S7 Screen Replacement, Battery Connector: step 11, image 2 of 2
      • Use the flat end of a spudger to disconnect the battery connector.
      Ask FixBot
    1. Samsung Galaxy S7 Screen Replacement, Screen: step 12, image 1 of 2 Samsung Galaxy S7 Screen Replacement, Screen: step 12, image 2 of 2
      • Use the flat end of a spudger to unplug the display and digitizer connector.
      Ask FixBot
    2. Samsung Galaxy S7 Screen Replacement: step 13, image 1 of 1
      • Prepare an iOpener and apply to a long edge of the phone for about 2 minutes.
      • The glue securing the display can be significantly stronger than the glue that secures the back cover. If necessary, switch to a hair dryer or heat gun in order to apply enough heat to weaken the adhesive.
      Ask FixBot
    3. Samsung Galaxy S7 Screen Replacement: step 14, image 1 of 3 Samsung Galaxy S7 Screen Replacement: step 14, image 2 of 3 Samsung Galaxy S7 Screen Replacement: step 14, image 3 of 3
      • Once the screen is warm to the touch, apply a suction cup as close to the heated edge of the phone as you can.
      • If your display is badly cracked, the suction cup may not stick. Try lifting the display with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
      • Lift on the suction cup, and insert an opening pick under the display assembly.
      Ask FixBot
    4. Samsung Galaxy S7 Screen Replacement: step 15, image 1 of 1
      • Once the pick is firmly inserted underneath the display, reheat and reapply the iOpener to soften the display adhesive.
      Ask FixBot
    5. Samsung Galaxy S7 Screen Replacement: step 16, image 1 of 2 Samsung Galaxy S7 Screen Replacement: step 16, image 2 of 2
      • Slide the opening pick down the side of the phone, separating the adhesive.
      • The display cable is located just above the midpoint on this side, and may interfere with your pick if you pry too deeply.
      Ask FixBot
    6. Samsung Galaxy S7 Screen Replacement: step 17, image 1 of 3 Samsung Galaxy S7 Screen Replacement: step 17, image 2 of 3 Samsung Galaxy S7 Screen Replacement: step 17, image 3 of 3
      • Leave an opening pick on each side as you continue to prevent the adhesive from resealing.
      • Don't cut too deep on the top or bottom, or you may damage the front-facing sensors or speaker assembly on the top, or capacitive buttons on the bottom.
      Ask FixBot
    7. Samsung Galaxy S7 Screen Replacement: step 18, image 1 of 2 Samsung Galaxy S7 Screen Replacement: step 18, image 2 of 2
      • Pry up the side of the display opposite the display cable so that the cable acts like a hinge as the phone opens.
      Ask FixBot
    8. Samsung Galaxy S7 Screen Replacement: step 19, image 1 of 2 Samsung Galaxy S7 Screen Replacement: step 19, image 2 of 2
      • Carefully lift the display away from the mid frame, gently pulling the display connector through the hole in the mid frame.
      • Remove the display.
      Ask FixBot
    9. Samsung Galaxy S7 Screen Replacement: step 20, image 1 of 1
      • Follow this link for a detailed screen adhesive application guide.
      • Before installing a new display, it's very important to remove all traces of the old adhesive from the frame, while taking special care to remove any small glass fragments.
      • After removing all traces of glue and glass from the frame, clean the adhesion areas with 90% (or higher) isopropyl alcohol and a lint-free cloth or coffee filter. Swipe in one direction only, not back and forth.
      • This helps remove any remaining adhesive residue and preps the surface for the new display.
      • If the frame is bent, or if any glue or glass remnants are left behind, the new display will not mount correctly and may be damaged.
      Ask FixBot
To reassemble your device, apply the adhesive to the rear cover and follow these instructions in reverse order.
187 other people completed this guide.
Sam Goldheart
478,447 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
30 Guide Comments
The screen replacement went smooth. I just wish it included the adhesive. I didn't see the note where the adhesive needed to be ordered in addition to the screen. Otherwise everything went well.
Thanks
march11934 - Reply Share
Samsung s7 ekran değişimi orjinal parça satın aldığınız zaman bu kadar uğraşmanıza gerek yok.
Yapıştırıcı da sadece arka kapağı yapıştırmak için gerekli oluyor
CitrusMobil - Reply Share
For the price of the screen, I can replace it in a Samsung repair center...
I just need to replace the glass, not all of the AMOLED touch screen... :-( Sorry but this didn't help me.
Darky - Reply Share
How much cost u paid to service centre for original display for samsung s7
Durgaprasad - Reply Share
You can not replace just the glass without special equipment (hot plate, laminator etc.)
Dinan Blueje - Reply Share
Past 24 Hours: 6
Past 7 Days: 54
Past 30 Days: 339
All Time: 379,042
