Samsung Galaxy S7 Active Screen Replacement
    1. Samsung Galaxy S7 Active Screen Replacement, Samsung Galaxy S7 Active Disassembly: step 1, image 1 of 1
      • Melt the adhesive on the screen by applying a blow dryer directly on the screen.
      • Your phone is hot, please do not touch it with your bare hand.
      Ask FixBot
    2. Samsung Galaxy S7 Active Screen Replacement: step 2, image 1 of 1
      • Wedge the metal spudger in between the screen and the frame to begin separating them.
      • It would be easier to separate the screen from the sealing adhesive on the frame if you do it with more than one metal spudger.
      • Your phone might no longer be watertight after you reassemble it.
      Ask FixBot
    3. Samsung Galaxy S7 Active Screen Replacement: step 3, image 1 of 2 Samsung Galaxy S7 Active Screen Replacement: step 3, image 2 of 2
      • Slide the metal spudger around the phone at least once.
      • It would be easier to slide your metal spudger if you apply the blow dryer to where you are currently sliding.
      Ask FixBot
    4. Samsung Galaxy S7 Active Screen Replacement: step 4, image 1 of 1
      • Lift the screen up with your hands.
      • Please wash your hands thoroughly with hot water and soap after you finish.
      Ask FixBot
    1. Samsung Galaxy S7 Active Screen Replacement, Screen: step 5, image 1 of 3 Samsung Galaxy S7 Active Screen Replacement, Screen: step 5, image 2 of 3 Samsung Galaxy S7 Active Screen Replacement, Screen: step 5, image 3 of 3
      Tool used on this step:
      Buy
      • Use the tweezers to disconnect the screen from the phone by detaching the connection.
      Ask FixBot
    2. Samsung Galaxy S7 Active Screen Replacement: step 6, image 1 of 3 Samsung Galaxy S7 Active Screen Replacement: step 6, image 2 of 3 Samsung Galaxy S7 Active Screen Replacement: step 6, image 3 of 3
      • Clean the rest of the adhesive left on the phone by scraping it off with a metal tool.
      • Apply rubbing alcohol on the adhesive to make sure phone is free of any adhesive. Do this by applying some rubbing alcohol onto a napkin.
      • Lightly proceed to clean the phone with that napkin.
      Ask FixBot
3 other people completed this guide.
Erick Vazquez
180 Reputation
1 Guide authored
Cal Poly, Team S18-G1, Livingston Spring 2018 Member of Cal Poly, Team S18-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G1
4 Members
96 Guides authored
3 Guide Comments
Do you know where i can find a replacement screen assembly, cant find one anywhere
Sam Ellis - Reply Share
I bought a digitizer with fog and polarizer and a new front glass, it came with the loca. What else do I need to make the complete LCD screen assembly?
Michael Shep - Reply Share
The instructions are excessively brief. The photos are insufficient to convey the details of this operation. Attempted and damaged my phone.
RAC - Reply Share
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 71
All Time: 9,959
