Samsung Galaxy S7 Active Disassembly
    1. Samsung Galaxy S7 Active Disassembly, Samsung Galaxy S7 Active Disassembly: step 1, image 1 of 1
      • Melt the adhesive on the screen by applying a blow dryer directly on the screen.
      • Your phone is hot, please do not touch it with your bare hand.
      Ask FixBot
    2. Samsung Galaxy S7 Active Disassembly: step 2, image 1 of 1
      • Wedge the metal spudger in between the screen and the frame to begin separating them.
      • It would be easier to separate the screen from the sealing adhesive on the frame if you do it with more than one metal spudger.
      • Your phone might no longer be watertight after you reassemble it.
      Ask FixBot
    3. Samsung Galaxy S7 Active Disassembly: step 3, image 1 of 2 Samsung Galaxy S7 Active Disassembly: step 3, image 2 of 2
      • Slide the metal spudger around the phone at least once.
      • It would be easier to slide your metal spudger if you apply the blow dryer to where you are currently sliding.
      Ask FixBot
    4. Samsung Galaxy S7 Active Disassembly: step 4, image 1 of 1
      • Lift the screen up with your hands.
      • Please wash your hands thoroughly with hot water and soap after you finish.
      Ask FixBot
3 other people completed this guide.
Chengbin Owen Kuang
207 Reputation
1 Guide authored
Cal Poly, Team S18-G1, Livingston Spring 2018 Member of Cal Poly, Team S18-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G1
4 Members
96 Guides authored
1 Guide Comment
What about fixing the phone sure you can take it apart but what about fixing
Robert Ydstie - Reply Share
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 69
All Time: 5,163
