Samsung Galaxy S7 Active Battery Replacement
  1. Samsung Galaxy S7 Active Battery Replacement, Samsung Galaxy S7 Active Disassembly: step 1, image 1 of 1
    • Melt the adhesive on the screen by applying a blow dryer directly on the screen.
    • Your phone is hot, please do not touch it with your bare hand.
  2. Samsung Galaxy S7 Active Battery Replacement: step 2, image 1 of 1
    • Wedge the metal spudger in between the screen and the frame to begin separating them.
    • It would be easier to separate the screen from the sealing adhesive on the frame if you do it with more than one metal spudger.
    • Your phone might no longer be watertight after you reassemble it.
  3. Samsung Galaxy S7 Active Battery Replacement: step 3, image 1 of 2 Samsung Galaxy S7 Active Battery Replacement: step 3, image 2 of 2
    • Slide the metal spudger around the phone at least once.
    • It would be easier to slide your metal spudger if you apply the blow dryer to where you are currently sliding.
  4. Samsung Galaxy S7 Active Battery Replacement: step 4, image 1 of 1
    • Lift the screen up with your hands.
    • Please wash your hands thoroughly with hot water and soap after you finish.
  5. Samsung Galaxy S7 Active Battery Replacement, Battery: step 5, image 1 of 1
    • Use a Phillips #000 screwdriver to remove a single screw.
  6. Samsung Galaxy S7 Active Battery Replacement: step 6, image 1 of 1
    Tool used on this step:
    Buy
    • Use tweezers to remove the small plastic cover you just unscrewed.
  7. Samsung Galaxy S7 Active Battery Replacement: step 7, image 1 of 1
    • Use tweezers to remove the other small plastic cover.
  8. Samsung Galaxy S7 Active Battery Replacement: step 8, image 1 of 1
    • Use a Phillips head #000 to take out the eleven screws marked in the photo.
  9. Samsung Galaxy S7 Active Battery Replacement: step 9, image 1 of 1
    • Use tweezers to disconnect the marked pieces from the motherboard.
  10. Samsung Galaxy S7 Active Battery Replacement: step 10, image 1 of 1
    • Use tweezers to take out the middle button and its connection to the motherboard.
  11. Samsung Galaxy S7 Active Battery Replacement: step 11, image 1 of 3 Samsung Galaxy S7 Active Battery Replacement: step 11, image 2 of 3 Samsung Galaxy S7 Active Battery Replacement: step 11, image 3 of 3
    • Use a metal spudger to pull the mid frame and battery off of the motherboard.
  12. Samsung Galaxy S7 Active Battery Replacement: step 12, image 1 of 2 Samsung Galaxy S7 Active Battery Replacement: step 12, image 2 of 2
    • Use a spudger to remove the battery from the midframe.
    • To install a new battery and adhesive, follow this guide.
11 other people completed this guide.
Alexander Yazdani
846 Reputation
3 Guides authored
Cal Poly, Team S18-G1, Livingston Spring 2018 Member of Cal Poly, Team S18-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G1
4 Members
15 Guides authored
4 Guide Comments
I would advise against using a metal spudger to remove the battery itself. While working at a device repair chain in the past, a coworker of mine punctured a battery with a metal spudger and destroyed the phone. Instead, use a sturdy plastic spudger to remove the battery. Otherwise, great guide!
Derek Margheim - Reply Share
I got the battery fixed but shattered my screen wish it was more informative on how to get out the screen
joshua hofer - Reply Share
Would using the Anti-clamp with heat gun be better option?
Kiriakos White - Reply Share
There is a YT video where a famed smartphone repairer makes it look easy but in the comments people are saying they broke their screen. The videographer doesn’t reply to comments.
The guy uses a plastic (I think) business card to lift the screen, sliding it under at the bottom and gradually pulling the protruding sides of the card all the way to the top. I don’t have one so I bought a plastic yogurt carton. I am not sure how well its plastic will withstand heat. A source of heatproof plastic, or nylon card please?
How hot can I heat the screen? I have a non contact thermometer.
I also wonder whether the same glue will work. It doesn’t need to be waterproof.
I think I am going to destroy my phone. I wish there were rugged phone with changeable batteries. I love my S6 active but it is start to not run apps eg LINE.
Timothy Takemoto - Reply Share
Past 24 Hours: 2
Past 7 Days: 27
Past 30 Days: 106
All Time: 26,332
