Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
Introduction
Go to step 1 ↓This guide will show you how to replace the Samsung Galaxy S7 Active front camera.
Melt the adhesive on the screen by applying a blow dryer directly on the screen.
Tool used on this step:Tweezers$4.99
Use tweezers to disconnect the front camera from the battery.
Use a Phillips 000 screwdriver to remove the screw covering the proximity sensor.
Use tweezers to remove the connection between the motherboard and the front camera.
