Samsung Galaxy S6 Active Rear Camera Replacement
    1. Samsung Galaxy S6 Active Rear Camera Replacement, SIM Card: step 1, image 1 of 2 Samsung Galaxy S6 Active Rear Camera Replacement, SIM Card: step 1, image 2 of 2
      • Insert your fingernail or a plastic opening tool into the pivot on the side of the SIM tray.
      • Pry open the tray to get it out of the socket.
      Ask FixBot
    2. Samsung Galaxy S6 Active Rear Camera Replacement: step 2, image 1 of 1
      • Remove the SIM tray with SIM card from the phone.
      Ask FixBot
    1. Samsung Galaxy S6 Active Rear Camera Replacement, Display Assembly: step 3, image 1 of 3 Samsung Galaxy S6 Active Rear Camera Replacement, Display Assembly: step 3, image 2 of 3 Samsung Galaxy S6 Active Rear Camera Replacement, Display Assembly: step 3, image 3 of 3
      • Heat the front face (sides, top, bottom) of the phone with the iOpener, a hair dryer, or a heat gun for 60 seconds to loosen the adhesive around the edge of the glass.
      • If using an iOpener, heat it in a microwave for thirty seconds.
      Ask FixBot
    2. Samsung Galaxy S6 Active Rear Camera Replacement: step 4, image 1 of 1
      • Attach a suction cup to the lower half of the screen.
      Ask FixBot
    3. Samsung Galaxy S6 Active Rear Camera Replacement: step 5, image 1 of 2 Samsung Galaxy S6 Active Rear Camera Replacement: step 5, image 2 of 2
      • Using the suction cup, pull gently the lower half of the panel.
      • If you pull too hard you may break the display. If you still feel resistance repeat Step 3, leaving the iOpener on longer.
      Ask FixBot
    4. Samsung Galaxy S6 Active Rear Camera Replacement: step 6, image 1 of 3 Samsung Galaxy S6 Active Rear Camera Replacement: step 6, image 2 of 3 Samsung Galaxy S6 Active Rear Camera Replacement: step 6, image 3 of 3
      • Once you’ve opened a large enough gap, insert a plastic tool at the bottom, between the glass and the rest of frame of the phone.
      • Slide the plastic opening tool around the screen, prying the display gently away from the body
      Ask FixBot
    5. Samsung Galaxy S6 Active Rear Camera Replacement: step 7, image 1 of 1
      • Pull the lower half of the screen screen with the suction cup while holding down the frame of the phone to separate both components.
      • Only lift the lower part of the screen. It is connected with a clip to the top of the motherboard and can rip off if you pull too hard.
      Ask FixBot
    6. Samsung Galaxy S6 Active Rear Camera Replacement: step 8, image 1 of 3 Samsung Galaxy S6 Active Rear Camera Replacement: step 8, image 2 of 3 Samsung Galaxy S6 Active Rear Camera Replacement: step 8, image 3 of 3
      Tool used on this step:
      Buy
      • Once the glass is off, you will see a small clip covering the screen connection to the motherboard at the top of the phone. Use tweezers to grab the clip by the crease on its side and pull it out.
      Ask FixBot
    7. Samsung Galaxy S6 Active Rear Camera Replacement: step 9, image 1 of 1
      • Undo the screen connection with a plastic tool.
      Ask FixBot
    8. Samsung Galaxy S6 Active Rear Camera Replacement: step 10, image 1 of 1
      • Remove the display assembly (LCD and Digitizer).
      Ask FixBot
    1. Samsung Galaxy S6 Active Rear Camera Replacement, Battery: step 11, image 1 of 2 Samsung Galaxy S6 Active Rear Camera Replacement, Battery: step 11, image 2 of 2
      • Use the Phillips Head Screwdriver sized PH000 to remove the sixteen 4mm screws from the frame.
      Ask FixBot
    2. Samsung Galaxy S6 Active Rear Camera Replacement: step 12, image 1 of 1
      • Put a little pressure on the top, on the bottom, and on the sides of the phone to separate the rear case.
      • You will hear the clips start undoing themselves.
      Ask FixBot
    3. Samsung Galaxy S6 Active Rear Camera Replacement: step 13, image 1 of 2 Samsung Galaxy S6 Active Rear Camera Replacement: step 13, image 2 of 2
      • Once all the clips have popped, pull out the rear case to separate it from the frame with the battery.
      • The battery will be on the back side of this frame.
      Ask FixBot
    4. Samsung Galaxy S6 Active Rear Camera Replacement: step 14, image 1 of 1
      • Insert a plastic opening tool on the side of the frame and pull out the battery.
      Ask FixBot
    5. Samsung Galaxy S6 Active Rear Camera Replacement: step 15, image 1 of 2 Samsung Galaxy S6 Active Rear Camera Replacement: step 15, image 2 of 2
      • Remove the battery from the frame.
      Ask FixBot
    1. Samsung Galaxy S6 Active Rear Camera Replacement, Rear Camera: step 16, image 1 of 2 Samsung Galaxy S6 Active Rear Camera Replacement, Rear Camera: step 16, image 2 of 2
      • The rear camera will be attached to the motherboard on the rear case.
      • Use a plastic tool to undo the connection of the rear camera from the motherboard.
      Ask FixBot
    2. Samsung Galaxy S6 Active Rear Camera Replacement: step 17, image 1 of 1
      Buy
      • Use the tweezers to remove rear camera from motherboard.
      Ask FixBot
Lucia Valbuena
2,538 Reputation
8 Guides authored
USF Tampa, Team 1-5, Sullivan Spring 2017 Member of USF Tampa, Team 1-5, Sullivan Spring 2017
USFT-SULLIVAN-S17S1G5
3 Members
96 Guides authored
1 Guide Comment
I replaced the S6 Active’s old battery, and never touched the camera (that I know of) but now the camera does not work. I get ‘Camera Failure' error statement. Clearing Cache did not fix it.
Is the camera connection easy to accidently disconnect? Or to test? Don’t want to take my S6 Active apart again unnecessarily.
Susan Jamieson - Reply Share
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 105
All Time: 3,677
