Samsung Galaxy S5 microSD Card Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
    1. Samsung Galaxy S5 microSD Card Replacement, Battery: step 1, image 1 of 3 Samsung Galaxy S5 microSD Card Replacement, Battery: step 1, image 2 of 3 Samsung Galaxy S5 microSD Card Replacement, Battery: step 1, image 3 of 3
      • Remove the rear case by using moderate force to pry the divot on the left of the rear facing camera with a plastic opening tool or your fingernail.
      • Continue to lift the case, working your way around the perimeter until the entire rear cover is removed.
      Ask FixBot
    2. Samsung Galaxy S5 microSD Card Replacement: step 2, image 1 of 2 Samsung Galaxy S5 microSD Card Replacement: step 2, image 2 of 2
      • Lift the battery upward with your finger or plastic opening tool by pushing on the notch located on the bottom of the battery.
      • Remove the battery from the phone.
      Ask FixBot
    1. Samsung Galaxy S5 microSD Card Replacement, microSD Card: step 3, image 1 of 3 Samsung Galaxy S5 microSD Card Replacement, microSD Card: step 3, image 2 of 3 Samsung Galaxy S5 microSD Card Replacement, microSD Card: step 3, image 3 of 3
      • Gently slide out the SD card using your fingernail or a plastic opening tool.
      • For reassembly, gently slide in the microSD card until it stops.
      Ask FixBot
5 other people completed this guide.
Justin Uchimura
4,440 Reputation
7 Guides authored
Cal Poly, Team 10-57, Amido Spring 2014 Member of Cal Poly, Team 10-57, Amido Spring 2014
CPSU-AMIDO-S14S10G57
4 Members
96 Guides authored
1 Guide Comment
Actually the battery does not even have to be removed (just unmount in settings first to avoid corruption)
Simply slide the card back until it runs into the battery, then just lift out.
BFeely - Reply Share
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 22
All Time: 5,033
