Grammar Police
Embrace your inner English teacher and help improve this guide's grammar!
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Community-Contributed Guide
Introduction
Go to step 1 ↓Follow the steps of this guide to replace a broken/non-functioning display on the Samsung Galaxy S5 Neo. After following these steps, you will also be in a better position to proceed with further teardown, if necessary for other repairs.
Use your fingernail or a pry tool to remove the rear plastic cover of the device, by pulling back on the edges.
Heat the display edges adequately at 80 degrees Celsius (176°F), then proceed to detach the display by inserting flat opening tools between the display glass and the frame.
Be careful not to rip the flat cables that lie underneath the lower part of the phone, near the button.
Be careful not to rip the flat display connectors that lie underneath the upper part of the phone.
!!!!CAUTION!!!! The display is also glued in the middle with strong double-sided adhesive. Be very careful if the display is not broken, otherwise you may end up having to replace it with a new one.
If you only need to remove the display to access the inside of the phone and perform other repairs, be wary of to the central adhesive and ensure you heat it carefully.
The pink strips are part of the very strong adhesive that could break the display.
To assemble the device, follow these instructions in reverse order.
42 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
16 Guide Comments
slt le problem que j ait un sm- g800f copy
c est pas originale et j arive pas a trouver l aficheur qui ce convien a lui
j besoin de votre aide pour avoir un aficheur pour tlphon portable sm-g800f fcc id:a3lsmg800f made korea by samsung
Not sure, but it sounds like he's looking for a display to fit a Samsung Galaxy S5 Mini (sm- g800f) that may or may not be a fake? There are a lot of shorthand and typos in there though...
