Samsung Galaxy S5 Mini Daughterboard Replacement
Video Overview
    1. Samsung Galaxy S5 Mini Daughterboard Replacement, Daughterboard: step 1, image 1 of 1
      • Remove the back cover.
      • Ther is an indent to insert your fingernail and unclip the back panel.
      Ask FixBot
    2. Samsung Galaxy S5 Mini Daughterboard Replacement: step 2, image 1 of 1
      • Remove the battery. If you have the SIM card and SD card in, remove them as well.
      • Whe re-assembling, make sure the battery contacts line up.
      Ask FixBot
    3. Samsung Galaxy S5 Mini Daughterboard Replacement: step 3, image 1 of 2 Samsung Galaxy S5 Mini Daughterboard Replacement: step 3, image 2 of 2
      • Open this small cover and release the home button flex connector.
      Ask FixBot
    4. Samsung Galaxy S5 Mini Daughterboard Replacement: step 4, image 1 of 3 Samsung Galaxy S5 Mini Daughterboard Replacement: step 4, image 2 of 3 Samsung Galaxy S5 Mini Daughterboard Replacement: step 4, image 3 of 3
      • Heat up the screen and cut the adhesive around the screen. Pry it up and release the LCD screen connector.
      • The connector is located at the top right of the screen, so lift it up or to the left.
      Ask FixBot
    5. Samsung Galaxy S5 Mini Daughterboard Replacement: step 5, image 1 of 2 Samsung Galaxy S5 Mini Daughterboard Replacement: step 5, image 2 of 2
      • Remove LCD screen.
      Ask FixBot
    6. Samsung Galaxy S5 Mini Daughterboard Replacement: step 6, image 1 of 2 Samsung Galaxy S5 Mini Daughterboard Replacement: step 6, image 2 of 2
      • Remove all the screws.
      Ask FixBot
    7. Samsung Galaxy S5 Mini Daughterboard Replacement: step 7, image 1 of 2 Samsung Galaxy S5 Mini Daughterboard Replacement: step 7, image 2 of 2
      • Remove mid-plate.
      Ask FixBot
    8. Samsung Galaxy S5 Mini Daughterboard Replacement: step 8, image 1 of 3 Samsung Galaxy S5 Mini Daughterboard Replacement: step 8, image 2 of 3 Samsung Galaxy S5 Mini Daughterboard Replacement: step 8, image 3 of 3
      • Remove screw, release USB board flex connector and antenna cable connectors.
      Ask FixBot
    9. Samsung Galaxy S5 Mini Daughterboard Replacement: step 9, image 1 of 2 Samsung Galaxy S5 Mini Daughterboard Replacement: step 9, image 2 of 2
      • Remove the daughterboard and clean the signal cables from assembly. And you can replace the new USB charging board for Samsung Galaxy S5 Mini.
      Ask FixBot
7 other people completed this guide.
Sophia
43,911 Reputation
62 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 32
Past 30 Days: 103
All Time: 6,643
