Samsung Galaxy S5 Mini Battery Replacement
    1. Samsung Galaxy S5 Mini Battery Replacement, Rear Panel: step 1, image 1 of 3 Samsung Galaxy S5 Mini Battery Replacement, Rear Panel: step 1, image 2 of 3 Samsung Galaxy S5 Mini Battery Replacement, Rear Panel: step 1, image 3 of 3
      • Insert a fingernail or a plastic opening tool into the slot located above the power button.
      • Gently pull the panel off the back of the phone.
      • The plastic snaps will make a popping sound as they separate.
      Ask FixBot
    1. Samsung Galaxy S5 Mini Battery Replacement, Battery: step 2, image 1 of 3 Samsung Galaxy S5 Mini Battery Replacement, Battery: step 2, image 2 of 3 Samsung Galaxy S5 Mini Battery Replacement, Battery: step 2, image 3 of 3
      • Insert fingernail or plastic opening tool into the slot at the bottom of the battery.
      • Gently pry the battery away from the phone.
      • When replacing the battery, ensure the contacts are aligned and press lightly. The battery will appear to fit in multiple directions, so do not force it in.
      Ask FixBot
8 other people completed this guide.
Ethan Juhnke
171 Reputation
1 Guide authored
Cal Poly, Team 12-4, Forte Fall 2014 Member of Cal Poly, Team 12-4, Forte Fall 2014
CPSU-FORTE-F14S12G4
5 Members
96 Guides authored
2 Guide Comments
that was so so hard!
dennysb de - Reply Share
But battery not charging properly
kapil jadhav - Reply Share
Past 24 Hours: 4
Past 7 Days: 32
Past 30 Days: 138
All Time: 11,962
