Introduction
The home button in the Samsung Galaxy S5 doubles as a fingerprint reader. The fingerprint reader functionality relies on a fragile cable assembly that is commonly broken upon opening the device. Follow the instructions in this guide to replace a broken home button, or transfer your old home button to your new screen if your replacement screen did not come with one.
This guide is a conditional add-on to the Display Assembly guide, and begins after the last step of that guide.
The clear rubber backing of the home button assembly is lightly adhered to the back of the display. The adhesive should be easy to cut through with an opening tool. If you have trouble removing the assembly in the following steps, try heating the area using an iOpener or a hair dryer to loosen the adhesive.
To finish reassembling your device, head back over to the Display Assembly guide!
8 other people completed this guide.
