Samsung Galaxy S5 Battery Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
    1. Samsung Galaxy S5 Battery Replacement, Battery: step 1, image 1 of 3 Samsung Galaxy S5 Battery Replacement, Battery: step 1, image 2 of 3 Samsung Galaxy S5 Battery Replacement, Battery: step 1, image 3 of 3
      • Remove the rear case by using moderate force to pry the divot on the left of the rear facing camera with a plastic opening tool or your fingernail.
      • Continue to lift the case, working your way around the perimeter until the entire rear cover is removed.
      Ask FixBot
    2. Samsung Galaxy S5 Battery Replacement: step 2, image 1 of 2 Samsung Galaxy S5 Battery Replacement: step 2, image 2 of 2
      • Lift the battery upward with your finger or plastic opening tool by pushing on the notch located on the bottom of the battery.
      • Remove the battery from the phone.
      Ask FixBot
11 other people completed this guide.
Justin Uchimura
4,440 Reputation
7 Guides authored
Cal Poly, Team 10-57, Amido Spring 2014 Member of Cal Poly, Team 10-57, Amido Spring 2014
CPSU-AMIDO-S14S10G57
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 19
All Time: 4,089
