Samsung Galaxy S4 Midframe Replacement
    1. Samsung Galaxy S4 Midframe Replacement, Rear Case: step 1, image 1 of 2 Samsung Galaxy S4 Midframe Replacement, Rear Case: step 1, image 2 of 2
      • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
      Ask FixBot
    2. Samsung Galaxy S4 Midframe Replacement: step 2, image 1 of 3 Samsung Galaxy S4 Midframe Replacement: step 2, image 2 of 3 Samsung Galaxy S4 Midframe Replacement: step 2, image 3 of 3
      • Lift the rear case by the corner nearest the divot and remove it from the phone.
      Ask FixBot
    1. Samsung Galaxy S4 Midframe Replacement, MicroSD Card: step 3, image 1 of 3 Samsung Galaxy S4 Midframe Replacement, MicroSD Card: step 3, image 2 of 3 Samsung Galaxy S4 Midframe Replacement, MicroSD Card: step 3, image 3 of 3
      • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
      • After the click, release the card and it will pop out of its slot.
      • Remove the microSD card.
      • For reassembly, push the microSD card into the slot until it clicks in place.
      Ask FixBot
    1. Samsung Galaxy S4 Midframe Replacement, Battery: step 4, image 1 of 3 Samsung Galaxy S4 Midframe Replacement, Battery: step 4, image 2 of 3 Samsung Galaxy S4 Midframe Replacement, Battery: step 4, image 3 of 3
      • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
      • Remove the battery from your phone.
      Ask FixBot
    1. Samsung Galaxy S4 Midframe Replacement, SIM Card: step 5, image 1 of 3 Samsung Galaxy S4 Midframe Replacement, SIM Card: step 5, image 2 of 3 Samsung Galaxy S4 Midframe Replacement, SIM Card: step 5, image 3 of 3
      • Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
      • Remove the SIM card.
      • During reassembly, push the SIM card into the slot until it clicks in place.
      Ask FixBot
    1. Samsung Galaxy S4 Midframe Replacement, Midframe: step 6, image 1 of 1
      • Remove the nine 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
      Ask FixBot
    2. Samsung Galaxy S4 Midframe Replacement: step 7, image 1 of 2 Samsung Galaxy S4 Midframe Replacement: step 7, image 2 of 2
      • The midframe is secured to the display assembly by several plastic clips behind the chrome bezel of the midframe. The next few steps will guide you through separating the clips to free the midframe.
      • Starting on the volume button side of the phone, insert your plastic opening tool between the chrome bezel around the display glass and the larger chrome border piece. Look for the seam between the two.
      • Slide the opening tool along the seam, separating the plastic clips as you go.
      • Be very gentle whilst prying, and pry only enough to separate the plastic clips—there are several thin points in the midframe bezel that may crack if you bend them too much.
      Ask FixBot
    3. Samsung Galaxy S4 Midframe Replacement: step 8, image 1 of 2 Samsung Galaxy S4 Midframe Replacement: step 8, image 2 of 2
      • Continue prying around the corner of the phone.
      • Slide your opening tool along the seam between the midframe and display along the bottom of the device, releasing more of the plastic clips.
      Ask FixBot
    4. Samsung Galaxy S4 Midframe Replacement: step 9, image 1 of 2 Samsung Galaxy S4 Midframe Replacement: step 9, image 2 of 2
      • Again, pry around the corner, to the power button side.
      • Slide the opening tool along the seam.
      Ask FixBot
    5. Samsung Galaxy S4 Midframe Replacement: step 10, image 1 of 2 Samsung Galaxy S4 Midframe Replacement: step 10, image 2 of 2
      • Continue sliding the opening tool around the top of the phone, releasing the last of the clips and freeing the midframe from the display assembly.
      • At this point, you may want to run your plastic opening tool along the entire perimeter of the device again, to make sure you've released all of the plastic clips.
      Ask FixBot
    6. Samsung Galaxy S4 Midframe Replacement: step 11, image 1 of 3 Samsung Galaxy S4 Midframe Replacement: step 11, image 2 of 3 Samsung Galaxy S4 Midframe Replacement: step 11, image 3 of 3
      • Remove the midframe from the display assembly.
      Ask FixBot
93 other people completed this guide.
Sam Goldheart
478,447 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
5 Guide Comments
I cracked the "front facing" bezel on my phone. I thought buying a new mid frame would replace it, but based on these pictures, it looks like it is attached to the the front glass. Is this correct? Is there any way to replace just that front facing bezel?
Marwan - Reply Share
i was wondering the same thing. Can you guys please respond.
Rival Archer - Reply Share
Yes, the bezel is attached to the front glass. Replacing the glass doesnt cost too much (under 15 eur here) but theres a high chance you will break the lcd digitizer in the process. It needs some skill.
Mark Bernstein - Reply Share
Hi... Is that the whole body is model GT-I9505 and How much it costs me the whole body?
Priya - Reply Share
Hi.. Is that the whole body is with mirror and how much it costs me??
Priya - Reply Share
Past 24 Hours: 6
Past 7 Days: 35
Past 30 Days: 154
All Time: 132,041
