Samsung Galaxy S4 Active Volume Button Replacement
    1. Samsung Galaxy S4 Active Volume Button Replacement, Rear Case: step 1, image 1 of 2 Samsung Galaxy S4 Active Volume Button Replacement, Rear Case: step 1, image 2 of 2
      • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
      • Lift the rear case by the corner nearest the divot and remove it from the phone.
      Ask FixBot
    1. Samsung Galaxy S4 Active Volume Button Replacement, MicroSD Card: step 2, image 1 of 1
      • Use a plastic opening tool, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
      • After the click, release the card and it will pop out of its slot.
      • Remove the microSD card.
      Ask FixBot
    1. Samsung Galaxy S4 Active Volume Button Replacement, Battery: step 3, image 1 of 1
      • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward to remove it.
      Ask FixBot
    1. Samsung Galaxy S4 Active Volume Button Replacement, SIM Card: step 4, image 1 of 1
      • Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
      • Remove the SIM card.
      Ask FixBot
    1. Samsung Galaxy S4 Active Volume Button Replacement, Midframe: step 5, image 1 of 1
      • Use the tip of a spudger to remove the four metallic pads located in each corner of the device.
      • Using a Phillips #00 screwdriver, remove the 12 screws connecting the midframe to the device.
      Ask FixBot
    2. Samsung Galaxy S4 Active Volume Button Replacement: step 6, image 1 of 1
      • Use the plastic opening tool to pry around the entire edge of the midframe now to release it from the front case.
      Ask FixBot
    1. Samsung Galaxy S4 Active Volume Button Replacement, Volume Button: step 7, image 1 of 1
      Tool used on this step:
      Buy
      • Pull the volume button out with a pair of blunt nose tweezers.
      Ask FixBot
    2. Samsung Galaxy S4 Active Volume Button Replacement: step 8, image 1 of 3 Samsung Galaxy S4 Active Volume Button Replacement: step 8, image 2 of 3 Samsung Galaxy S4 Active Volume Button Replacement: step 8, image 3 of 3
      • Use the flat end of a plastic opening tool to disconnect the USB board connector.
      • Disconnect the front-facing camera cable connector.
      • Disconnect the earpiece speaker assembly cable connector.
      • Disconnect the headphone jack assembly cable connector.
      • Disconnect the display/digitizer cable connector.
      • Disconnect the antenna cable connector.
      Ask FixBot
    3. Samsung Galaxy S4 Active Volume Button Replacement: step 9, image 1 of 1
      • Remove the single 2.4 mm Phillips #00 screw from the motherboard assembly.
      Ask FixBot
    4. Samsung Galaxy S4 Active Volume Button Replacement: step 10, image 1 of 1
      • Remove the motherboard.
      Ask FixBot
    5. Samsung Galaxy S4 Active Volume Button Replacement: step 11, image 1 of 1
      • Flip
      Ask FixBot
Geoff Wacker
93,075 Reputation
88 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 76
All Time: 1,575
