Samsung Galaxy S4 Active Motherboard Replacement
  1. Samsung Galaxy S4 Active Motherboard Replacement, Rear Case: step 1, image 1 of 2 Samsung Galaxy S4 Active Motherboard Replacement, Rear Case: step 1, image 2 of 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
    Ask FixBot
  2. Samsung Galaxy S4 Active Motherboard Replacement, MicroSD Card: step 2, image 1 of 1
    • Use a plastic opening tool, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    Ask FixBot
  3. Samsung Galaxy S4 Active Motherboard Replacement, Battery: step 3, image 1 of 1
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward to remove it.
    Ask FixBot
  4. Samsung Galaxy S4 Active Motherboard Replacement, SIM Card: step 4, image 1 of 1
    • Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
    • Remove the SIM card.
    Ask FixBot
  5. Samsung Galaxy S4 Active Motherboard Replacement, Midframe: step 5, image 1 of 1
    • Use the tip of a spudger to remove the four metallic pads located in each corner of the device.
    • Using a Phillips #00 screwdriver, remove the 12 screws connecting the midframe to the device.
    Ask FixBot
  6. Samsung Galaxy S4 Active Motherboard Replacement: step 6, image 1 of 1
    • Use the plastic opening tool to pry around the entire edge of the midframe now to release it from the front case.
    Ask FixBot
  7. Samsung Galaxy S4 Active Motherboard Replacement, Motherboard: step 7, image 1 of 3 Samsung Galaxy S4 Active Motherboard Replacement, Motherboard: step 7, image 2 of 3 Samsung Galaxy S4 Active Motherboard Replacement, Motherboard: step 7, image 3 of 3
    • Use the flat end of a plastic opening tool to disconnect the USB board connector.
    • Disconnect the front-facing camera cable connector.
    • Disconnect the earpiece speaker assembly cable connector.
    • Disconnect the headphone jack assembly cable connector.
    • Disconnect the display/digitizer cable connector.
    • Disconnect the antenna cable connector.
    Ask FixBot
  8. Samsung Galaxy S4 Active Motherboard Replacement: step 8, image 1 of 1
    • Remove the single 2.4 mm Phillips #00 screw from the motherboard assembly.
    Ask FixBot
  9. Samsung Galaxy S4 Active Motherboard Replacement: step 9, image 1 of 1
    • Remove the motherboard.
    Ask FixBot
22 other people completed this guide.
Geoff Wacker
92,716 Reputation
89 Guides authored
4 Guide Comments
Kiitos paljon
Kimmo Vaalanti - Reply Share
I need a diagnosis. My device seems to be in a boot loop....any thought and suggestions would be helpful.
Justin Lujan - Reply Share
Nota1000 fera + parabéns
ricflavianoop - Reply Share
After the replacement of the motherboard, is there a procedure to Programm the old IMEI or will it imply a new IMEI?
Markus Elgrande - Reply Share
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 88
All Time: 9,904
