Samsung Galaxy S4 Active Front Facing Camera Replacement
    1. Samsung Galaxy S4 Active Front Facing Camera Replacement, Rear Case: step 1, image 1 of 2 Samsung Galaxy S4 Active Front Facing Camera Replacement, Rear Case: step 1, image 2 of 2
      • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
      • Lift the rear case by the corner nearest the divot and remove it from the phone.
      Ask FixBot
    1. Samsung Galaxy S4 Active Front Facing Camera Replacement, Battery: step 2, image 1 of 1
      • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward to remove it.
      Ask FixBot
    1. Samsung Galaxy S4 Active Front Facing Camera Replacement, MicroSD Card: step 3, image 1 of 1
      • Use a plastic opening tool, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
      • After the click, release the card and it will pop out of its slot.
      • Remove the microSD card.
      Ask FixBot
    1. Samsung Galaxy S4 Active Front Facing Camera Replacement, SIM Card: step 4, image 1 of 1
      • Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
      • Remove the SIM card.
      Ask FixBot
    1. Samsung Galaxy S4 Active Front Facing Camera Replacement, Midframe: step 5, image 1 of 1
      • Use the tip of a spudger to remove the four metallic pads located in each corner of the device.
      • Using a Phillips #00 screwdriver, remove the 12 screws connecting the midframe to the device.
      Ask FixBot
    2. Samsung Galaxy S4 Active Front Facing Camera Replacement: step 6, image 1 of 1
      • Use the plastic opening tool to pry around the entire edge of the midframe now to release it from the front case.
      Ask FixBot
    1. Samsung Galaxy S4 Active Front Facing Camera Replacement, Front Facing Camera: step 7, image 1 of 2 Samsung Galaxy S4 Active Front Facing Camera Replacement, Front Facing Camera: step 7, image 2 of 2
      • Using the Phillips #00 screwdriver, remove the single 0.3mm screw securing the black cover over the camera sensor.
      Ask FixBot
    2. Samsung Galaxy S4 Active Front Facing Camera Replacement: step 8, image 1 of 2 Samsung Galaxy S4 Active Front Facing Camera Replacement: step 8, image 2 of 2
      Tool used on this step:
      Buy
      • Using a pair of precision tweezers, remove the black camera backing.
      Ask FixBot
    3. Samsung Galaxy S4 Active Front Facing Camera Replacement: step 9, image 1 of 2 Samsung Galaxy S4 Active Front Facing Camera Replacement: step 9, image 2 of 2
      • Using a spudger, disconnect the blue press-fit connector by pulling up gently.
      • Lift the front-facing camera out of the device.
      Ask FixBot
Justin Ogihara
31,443 Reputation
52 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 33
All Time: 991
