Samsung Galaxy S3 Neo Battery Replacement
    1. Samsung Galaxy S3 Neo Battery Replacement, Rear Casing: step 1, image 1 of 3 Samsung Galaxy S3 Neo Battery Replacement, Rear Casing: step 1, image 2 of 3 Samsung Galaxy S3 Neo Battery Replacement, Rear Casing: step 1, image 3 of 3
      • Pry up the rear casing using the clip near the headphone jack shown in picture 2.
      • You may use a spudger for your this step. A jimmy tool may be used but is not recommended.
      • Do not force the back off on any other side!
      Ask FixBot
    2. Samsung Galaxy S3 Neo Battery Replacement, Battery: step 2, image 1 of 3 Samsung Galaxy S3 Neo Battery Replacement, Battery: step 2, image 2 of 3 Samsung Galaxy S3 Neo Battery Replacement, Battery: step 2, image 3 of 3
      • Remove the battery via the small opening near the flash.
      • You may use a spudger for this. A jimmy tool is not recommended and should not be used.
      • Do not forget to turn off the phone before removing the battery!
      • Be careful when removing the battery; it can be punctured.
      Ask FixBot
Tudor Voicu
268 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 36
All Time: 341
