Samsung Galaxy S24 Ultra Screen Replacement
    1. Samsung Galaxy S24 Ultra Screen Replacement, Prepare your phone for disassembly: step 1, image 1 of 2 Samsung Galaxy S24 Ultra Screen Replacement, Prepare your phone for disassembly: step 1, image 2 of 2
      • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard. If your battery is swollen, take appropriate precautions.
      • Unplug any cables from your phone.
      • Hold the side key and the volume down button, then select "Power off" to turn off your phone.
      Ask FixBot
    1. Samsung Galaxy S24 Ultra Screen Replacement, Heat the right edge: step 2, image 1 of 1
      • Heat an iOpener and apply it to the right edge of the back cover for two minutes.
      • You may use a hair dryer, heat gun, or hot plate instead, but be careful not to overheat the phone—the display and internal battery are susceptible to heat damage.
      Ask FixBot
    2. Samsung Galaxy S24 Ultra Screen Replacement, Insert an opening pick: step 3, image 1 of 3 Samsung Galaxy S24 Ultra Screen Replacement, Insert an opening pick: step 3, image 2 of 3 Samsung Galaxy S24 Ultra Screen Replacement, Insert an opening pick: step 3, image 3 of 3
      • Apply a suction handle to the back cover, as close to the center of the right edge as possible.
      • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
      • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
      • Insert an opening pick into the gap.
      Ask FixBot
    3. Samsung Galaxy S24 Ultra Screen Replacement, Separate the right adhesive: step 4, image 1 of 3 Samsung Galaxy S24 Ultra Screen Replacement, Separate the right adhesive: step 4, image 2 of 3 Samsung Galaxy S24 Ultra Screen Replacement, Separate the right adhesive: step 4, image 3 of 3
      • Slide the pick back and forth along the right edge to separate the adhesive.
      • Leave the pick inserted near the bottom right corner to prevent the adhesive from resealing.
      Ask FixBot
    4. Samsung Galaxy S24 Ultra Screen Replacement, Heat the bottom edge: step 5, image 1 of 1
      • Apply a heated iOpener to the bottom edge of the back cover for two minutes.
      Ask FixBot
    5. Samsung Galaxy S24 Ultra Screen Replacement, Separate the bottom adhesive: step 6, image 1 of 3 Samsung Galaxy S24 Ultra Screen Replacement, Separate the bottom adhesive: step 6, image 2 of 3 Samsung Galaxy S24 Ultra Screen Replacement, Separate the bottom adhesive: step 6, image 3 of 3
      • Insert a second opening pick next to the first one, near the bottom of the right edge.
      • Rotate the opening pick around the bottom right corner to separate the adhesive.
      Ask FixBot
    6. Samsung Galaxy S24 Ultra Screen Replacement: step 7, image 1 of 2 Samsung Galaxy S24 Ultra Screen Replacement: step 7, image 2 of 2
      • Slide the opening pick along the bottom edge to separate the adhesive.
      • Leave the pick inserted near the bottom left corner to prevent the adhesive from resealing.
      Ask FixBot
    7. Samsung Galaxy S24 Ultra Screen Replacement, Heat the left edge: step 8, image 1 of 1
      • Apply a heated iOpener to the left edge of the back cover for two minutes.
      Ask FixBot
    8. Samsung Galaxy S24 Ultra Screen Replacement, Separate the left adhesive: step 9, image 1 of 3 Samsung Galaxy S24 Ultra Screen Replacement, Separate the left adhesive: step 9, image 2 of 3 Samsung Galaxy S24 Ultra Screen Replacement, Separate the left adhesive: step 9, image 3 of 3
      • Insert a third opening pick next to the second one, near the left side of the bottom edge.
      • Rotate the opening pick around the bottom left corner to separate the adhesive.
      Ask FixBot
    9. Samsung Galaxy S24 Ultra Screen Replacement: step 10, image 1 of 2 Samsung Galaxy S24 Ultra Screen Replacement: step 10, image 2 of 2
      • Slide your opening pick along the left edge to separate the adhesive, stopping before you reach the power button.
      • Do not insert the pick more than 4 mm to avoid damaging the antenna cable.
      • Leave the pick inserted near the power button to prevent the adhesive from resealing.
      Ask FixBot
    10. Samsung Galaxy S24 Ultra Screen Replacement, Heat the top edge: step 11, image 1 of 1
      • Apply a heated iOpener to the top edge of the back cover for two minutes.
      Ask FixBot
    11. Samsung Galaxy S24 Ultra Screen Replacement, Separate the top adhesive: step 12, image 1 of 3 Samsung Galaxy S24 Ultra Screen Replacement, Separate the top adhesive: step 12, image 2 of 3 Samsung Galaxy S24 Ultra Screen Replacement, Separate the top adhesive: step 12, image 3 of 3
      • Insert an opening pick in the gap at the top of the right edge.
      • Rotate the opening pick around the top right corner to separate the adhesive.
      Ask FixBot
    12. Samsung Galaxy S24 Ultra Screen Replacement: step 13, image 1 of 2 Samsung Galaxy S24 Ultra Screen Replacement: step 13, image 2 of 2
      • Slide the pick along the top edge to separate the adhesive.
      • Do not insert the pick more than 4 mm to avoid damaging the sensor or camera near the top edge.
      Ask FixBot
    13. Samsung Galaxy S24 Ultra Screen Replacement, Separate the remaining adhesive: step 14, image 1 of 3 Samsung Galaxy S24 Ultra Screen Replacement, Separate the remaining adhesive: step 14, image 2 of 3 Samsung Galaxy S24 Ultra Screen Replacement, Separate the remaining adhesive: step 14, image 3 of 3
      • Slide the pick around the top left corner and down the left edge to separate the remaining adhesive.
      • Do not insert the pick more than 4 mm to avoid damaging the cameras.
      Ask FixBot
    14. Samsung Galaxy S24 Ultra Screen Replacement, Remove the back cover: step 15, image 1 of 2 Samsung Galaxy S24 Ultra Screen Replacement, Remove the back cover: step 15, image 2 of 2
      • Grab and remove the back cover.
      • If your cover is still sticking to the frame, slide an opening pick around the edges to separate any adhesive that may have resealed.
      • During reassembly:
      • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
      • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
      • If you're using custom-cut adhesives, follow this guide.
      • If you're using double-sided tape, follow this guide.
      Ask FixBot
    1. Samsung Galaxy S24 Ultra Screen Replacement, Disconnect the wireless charging coil: step 16, image 1 of 2 Samsung Galaxy S24 Ultra Screen Replacement, Disconnect the wireless charging coil: step 16, image 2 of 2
      • Use a spudger to pry up and disconnect the wireless charging coil press connector from the motherboard.
      • There's an arrow printed on the board near each press connector that indicates the recommended prying location. Only pry in this location for each press connector to avoid dislodging surface-mounted components.
      • To reconnect press connectors, align the connector carefully over its socket and press down with your fingertip—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
      Ask FixBot
    2. Samsung Galaxy S24 Ultra Screen Replacement, Remove the wireless charging coil and loudspeaker screws: step 17, image 1 of 2 Samsung Galaxy S24 Ultra Screen Replacement, Remove the wireless charging coil and loudspeaker screws: step 17, image 2 of 2
      • Use a Phillips screwdriver to remove the ten 3.5 mm‑long screws securing the wireless charging coil and the loudspeaker:
      • Four screws securing the wireless charging coil
      • Six screws securing the loudspeaker
      Ask FixBot
    3. Samsung Galaxy S24 Ultra Screen Replacement, Separate the coil adhesive: step 18, image 1 of 2 Samsung Galaxy S24 Ultra Screen Replacement, Separate the coil adhesive: step 18, image 2 of 2
      • Use a spudger to gently pry up a corner of the tab of the wireless charging coil that's adhered to the right edge of the frame.
      Ask FixBot
    4. Samsung Galaxy S24 Ultra Screen Replacement: step 19, image 1 of 2 Samsung Galaxy S24 Ultra Screen Replacement: step 19, image 2 of 2
      • Use an opening pick to separate the tab from the frame.
      Ask FixBot
    5. Samsung Galaxy S24 Ultra Screen Replacement, Remove the wireless charging coil and loudspeaker: step 20, image 1 of 2 Samsung Galaxy S24 Ultra Screen Replacement, Remove the wireless charging coil and loudspeaker: step 20, image 2 of 2
      • Insert the point of a spudger into the gap between the right edge of the loudspeaker and the frame.
      • There's an arrow engraved in the loudspeaker to indicate the recommended prying location.
      • Pry up to unclip the loudspeaker from the frame.
      Ask FixBot
    6. Samsung Galaxy S24 Ultra Screen Replacement: step 21, image 1 of 2 Samsung Galaxy S24 Ultra Screen Replacement: step 21, image 2 of 2
      • Remove the wireless charging coil and loudspeaker from the frame.
      • During reassembly, press around the edges of the loudspeaker to clip it to the frame before reinserting the screws.
      Ask FixBot
    1. Samsung Galaxy S24 Ultra Screen Replacement, Disconnect the battery: step 22, image 1 of 2 Samsung Galaxy S24 Ultra Screen Replacement, Disconnect the battery: step 22, image 2 of 2
      • Use a spudger to pry up and disconnect the battery press connector.
      Ask FixBot
    1. Samsung Galaxy S24 Ultra Screen Replacement, Disconnect the interconnect cables: step 23, image 1 of 3 Samsung Galaxy S24 Ultra Screen Replacement, Disconnect the interconnect cables: step 23, image 2 of 3 Samsung Galaxy S24 Ultra Screen Replacement, Disconnect the interconnect cables: step 23, image 3 of 3
      • Use a spudger to pry up and disconnect both interconnect cable press connectors from the motherboard.
      Ask FixBot
    2. Samsung Galaxy S24 Ultra Screen Replacement: step 24, image 1 of 3 Samsung Galaxy S24 Ultra Screen Replacement: step 24, image 2 of 3 Samsung Galaxy S24 Ultra Screen Replacement: step 24, image 3 of 3
      • Use a spudger to pry up and disconnect both interconnect cable press connectors from the daughterboard.
      Ask FixBot
    3. Samsung Galaxy S24 Ultra Screen Replacement, Remove the interconnect cables: step 25, image 1 of 2 Samsung Galaxy S24 Ultra Screen Replacement, Remove the interconnect cables: step 25, image 2 of 2
      • Grab and remove the interconnect cables from the phone.
      Ask FixBot
    1. Samsung Galaxy S24 Ultra Screen Replacement, Remove the display cable: step 26, image 1 of 2 Samsung Galaxy S24 Ultra Screen Replacement, Remove the display cable: step 26, image 2 of 2
      • Use a spudger to pry up and disconnect the display cable press connector from the motherboard.
      Ask FixBot
    2. Samsung Galaxy S24 Ultra Screen Replacement: step 27, image 1 of 3 Samsung Galaxy S24 Ultra Screen Replacement: step 27, image 2 of 3 Samsung Galaxy S24 Ultra Screen Replacement: step 27, image 3 of 3
      • Use a spudger to pry up and disconnect the display cable press connector from the daughterboard.
      Ask FixBot
    3. Samsung Galaxy S24 Ultra Screen Replacement, Disconnect the fingerprint reader: step 28, image 1 of 2 Samsung Galaxy S24 Ultra Screen Replacement, Disconnect the fingerprint reader: step 28, image 2 of 2
      • Use a spudger to pry up and disconnect the fingerprint reader cable press connector from the motherboard.
      Ask FixBot
    4. Samsung Galaxy S24 Ultra Screen Replacement, Put the back cover on: step 29, image 1 of 2 Samsung Galaxy S24 Ultra Screen Replacement, Put the back cover on: step 29, image 2 of 2
      • Put the back cover on the frame to protect the battery and your phone's internals from damage.
      • Don't apply new adhesive at this step, as you'll need to remove the back cover again to finish reassembly. The old adhesive will be enough to keep the back cover in place while you replace the screen.
      • Flip your phone over so the screen is facing up.
      Ask FixBot
    5. Samsung Galaxy S24 Ultra Screen Replacement: step 30, image 1 of 1
      • If your screen is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
      • Make sure there's a smooth area near the top edge big enough for a suction cup to stick to.
      Ask FixBot
    6. Samsung Galaxy S24 Ultra Screen Replacement, Heat the screen: step 31, image 1 of 1
      • Be careful not to heat the phone more than recommended below—the battery is susceptible to heat damage.
      • Use a hair dryer or heat gun to heat the top edge of the screen until it's almost too hot to touch.
      Ask FixBot
    7. Samsung Galaxy S24 Ultra Screen Replacement, Safety information: step 32, image 1 of 3 Samsung Galaxy S24 Ultra Screen Replacement, Safety information: step 32, image 2 of 3 Samsung Galaxy S24 Ultra Screen Replacement, Safety information: step 32, image 3 of 3
      Tool used on this step:
      iFlex Opening Tool
      $11.99
      Buy
      • The gap between the front glass and frame is very small. You'll need a thin, rigid tool such as an iFlex to create an initial gap.
      • Take the following safety precautions while removing the front glass during the next steps:
      • Don't grip the iFlex or similar metal tools by the edges with bare hands—they're very sharp.
      • The front glass may shatter and spread shards of glass around your workspace. Consider wearing gloves and safety glasses to protect yourself.
      Ask FixBot
    8. Samsung Galaxy S24 Ultra Screen Replacement, Create a gap: step 33, image 1 of 3 Samsung Galaxy S24 Ultra Screen Replacement, Create a gap: step 33, image 2 of 3 Samsung Galaxy S24 Ultra Screen Replacement, Create a gap: step 33, image 3 of 3
      • The iFlex or similar tool only needs to be inserted just enough to create a small gap between the glass and the display panel. If inserted too far, it may damage the front-facing camera.
      • Apply a suction handle to the center of the screen's top edge, as close to the edge as possible.
      • Insert the iFlex or similar tool at a downward angle in the notch between the top edge of the front glass and frame.
      • Use strong, steady force to pry up the glass with the suction handle while gently pushing the iFlex between the glass and the display panel.
      • The front glass will peel away from the display panel, causing it to appear discolored. This is normal. You will remove the display panel in a later step.
      Ask FixBot
    9. Samsung Galaxy S24 Ultra Screen Replacement, Insert an opening pick: step 34, image 1 of 3 Samsung Galaxy S24 Ultra Screen Replacement, Insert an opening pick: step 34, image 2 of 3 Samsung Galaxy S24 Ultra Screen Replacement, Insert an opening pick: step 34, image 3 of 3
      • Slide the iFlex or similar tool to one of the top corners of the front glass until the gap is large enough to insert an opening pick.
      • Insert an opening pick into the gap and remove the iFlex.
      • Though you can use an iFlex for the next step, a plastic tool like an opening pick reduces the risk of shattering the glass.
      Ask FixBot
    10. Samsung Galaxy S24 Ultra Screen Replacement, Remove the front glass: step 35, image 1 of 3 Samsung Galaxy S24 Ultra Screen Replacement, Remove the front glass: step 35, image 2 of 3 Samsung Galaxy S24 Ultra Screen Replacement, Remove the front glass: step 35, image 3 of 3
      • Slide the opening pick around the edges of the front glass to separate the adhesive securing it to the frame.
      • If the adhesive is difficult to separate, use a hair dryer or heat gun to heat the sides of the phone until they're warm to the touch.
      Ask FixBot
    11. Samsung Galaxy S24 Ultra Screen Replacement: step 36, image 1 of 2 Samsung Galaxy S24 Ultra Screen Replacement: step 36, image 2 of 2
      • Lift the front glass off the frame and remove it.
      Ask FixBot
    12. Samsung Galaxy S24 Ultra Screen Replacement, Remove the display panel: step 37, image 1 of 2 Samsung Galaxy S24 Ultra Screen Replacement, Remove the display panel: step 37, image 2 of 2
      • Insert an opening pick under the display panel.
      • If you're having trouble separating the adhesive, use a hair dryer or heat gun to heat the display panel and soften its adhesive.
      • The display panel has two layers. Make sure the pick is completely underneath the display panel and not between two layers.
      Ask FixBot
    13. Samsung Galaxy S24 Ultra Screen Replacement: step 38, image 1 of 3 Samsung Galaxy S24 Ultra Screen Replacement: step 38, image 2 of 3 Samsung Galaxy S24 Ultra Screen Replacement: step 38, image 3 of 3
      • The fingerprint reader attaches to the display near the top left corner. Be careful not to pull on the cable with the opening pick to avoid damaging the motherboard.
      • There are components attached to the back of the bottom edge of the display panel, and gaskets under these components. Slide the opening pick under these components, but don't peel up the gaskets.
      • Slide the opening pick around the edges of the display panel to separate the adhesive securing it to the frame.
      Ask FixBot
    14. Samsung Galaxy S24 Ultra Screen Replacement: step 39, image 1 of 3 Samsung Galaxy S24 Ultra Screen Replacement: step 39, image 2 of 3 Samsung Galaxy S24 Ultra Screen Replacement: step 39, image 3 of 3
      Ask FixBot
    15. Samsung Galaxy S24 Ultra Screen Replacement: step 40, image 1 of 2 Samsung Galaxy S24 Ultra Screen Replacement: step 40, image 2 of 2
      • Remove the display panel.
      • You can use an opening pick to separate the adhesive underneath the display panel to make it easier to remove, being careful not to damage the front camera.
      Ask FixBot
15 other people completed this guide.
Spencer Pennington
26,977 Reputation
126 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
60,546 Guides authored
3 Guide Comments
Hi,
thank you for great description. Just wondering about one detail, which is not visible - is there some kind of protection (e.g. grill) between the display and the frame in the gap for the ear speaker? It is obviously not from the top, I can see that, but I mean below the display. Or is the sound conduit opened from the speaker to the gap on the surface? If so, it seems to be a great trap for dust.
Thanks
Pavel
Pavel - Reply Share
Great Guide. I was only frustrated at the end when I accidentally tore the gastket. Why are those extra Images Hyperlinked!? Why aren't the warning images included in the step pictures? It would be so much easier to not miss them.
JKing - Reply Share
Aus meiner Sicht fehlt zwischen Schritt 21 und Schritt 22 die Beschreibung den Akku abzuklemmen. Er muss abgeklemmt werden.
Auf der Abbildung bei Schritt 22 ist zu erkennen das er angesteckt ist.
Sonnst hat alles top funktioniert.
Danke!!!!
Stefan Almosdörfer - Reply Share
Past 24 Hours: 55
Past 7 Days: 425
Past 30 Days: 1,839
All Time: 40,989
