Samsung Galaxy S24 Plus Battery Replacement
Views: 9.5K
View statistics:
Past 24 Hours:
23
Past 7 Days:
160
Past 30 Days:
650
All Time:
9,546
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Follow this guide to replace a dead or worn-out battery in your Samsung Galaxy S24+.
This guide is for the battery only. If you're replacing the screen and battery assembly (the frame, screen, and battery as one piece), follow this guide instead.
Parts
Tools
    1. Samsung Galaxy S24 Plus Battery Replacement, Prepare your phone for disassembly: step 1, image 1 of 2 Samsung Galaxy S24 Plus Battery Replacement, Prepare your phone for disassembly: step 1, image 2 of 2
      • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard. If your battery is swollen, take appropriate precautions.
      • Unplug any cables from your phone.
      • Hold the side key and the volume down button, then select "Power off" to turn off your phone.
      Ask FixBot
    1. Samsung Galaxy S24 Plus Battery Replacement, Heat the right edge: step 2, image 1 of 1
      • Heat an iOpener and apply it to the right edge of the back cover for two minutes.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are susceptible to heat damage.
      Ask FixBot
    2. Samsung Galaxy S24 Plus Battery Replacement, Insert an opening pick: step 3, image 1 of 3 Samsung Galaxy S24 Plus Battery Replacement, Insert an opening pick: step 3, image 2 of 3 Samsung Galaxy S24 Plus Battery Replacement, Insert an opening pick: step 3, image 3 of 3
      • Apply a suction handle to the back cover, as close to the center of the right edge as possible.
      • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
      • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
      • Insert an opening pick into the gap.
      Ask FixBot
    3. Samsung Galaxy S24 Plus Battery Replacement, Separate the right adhesive: step 4, image 1 of 3 Samsung Galaxy S24 Plus Battery Replacement, Separate the right adhesive: step 4, image 2 of 3 Samsung Galaxy S24 Plus Battery Replacement, Separate the right adhesive: step 4, image 3 of 3
      • Slide the pick back and forth along the right edge to separate the adhesive.
      • Leave the pick inserted near the bottom right corner to prevent the adhesive from resealing.
      Ask FixBot
    4. Samsung Galaxy S24 Plus Battery Replacement, Heat the bottom edge: step 5, image 1 of 1
      • Apply a heated iOpener to the bottom edge of the back cover for two minutes.
      Ask FixBot
    5. Samsung Galaxy S24 Plus Battery Replacement, Separate the corner adhesive: step 6, image 1 of 2 Samsung Galaxy S24 Plus Battery Replacement, Separate the corner adhesive: step 6, image 2 of 2
      • Rotate the opening pick around the bottom right corner to separate the adhesive.
      Ask FixBot
    6. Samsung Galaxy S24 Plus Battery Replacement, Separate the bottom adhesive: step 7, image 1 of 2 Samsung Galaxy S24 Plus Battery Replacement, Separate the bottom adhesive: step 7, image 2 of 2
      • Insert a second pick at the bottom right corner.
      • Slide the opening pick to the bottom left corner to separate the adhesive.
      • Leave the pick in the bottom left corner to prevent the adhesive from resealing.
      Ask FixBot
    7. Samsung Galaxy S24 Plus Battery Replacement, Heat the left edge: step 8, image 1 of 1
      • Apply a heated iOpener to the left edge of the back cover for two minutes.
      Ask FixBot
    8. Samsung Galaxy S24 Plus Battery Replacement, Separate the corner adhesive: step 9, image 1 of 2 Samsung Galaxy S24 Plus Battery Replacement, Separate the corner adhesive: step 9, image 2 of 2
      • Rotate the opening pick around the bottom left corner to separate the adhesive.
      Ask FixBot
    9. Samsung Galaxy S24 Plus Battery Replacement, Separate the left adhesive: step 10, image 1 of 2 Samsung Galaxy S24 Plus Battery Replacement, Separate the left adhesive: step 10, image 2 of 2
      • Insert a third opening pick at the bottom left corner.
      • Slide the pick toward the top left corner to separate the adhesive.
      • Leave the pick near the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    10. Samsung Galaxy S24 Plus Battery Replacement, Heat the top edge: step 11, image 1 of 1
      • Apply a heated iOpener to the top edge of the back cover for two minutes.
      Ask FixBot
    11. Samsung Galaxy S24 Plus Battery Replacement, Separate the corner adhesive: step 12, image 1 of 2 Samsung Galaxy S24 Plus Battery Replacement, Separate the corner adhesive: step 12, image 2 of 2
      • Rotate the opening pick around the top left corner to separate the adhesive.
      Ask FixBot
    12. Samsung Galaxy S24 Plus Battery Replacement, Separate the top adhesive: step 13, image 1 of 2 Samsung Galaxy S24 Plus Battery Replacement, Separate the top adhesive: step 13, image 2 of 2
      • Insert a fourth opening pick at the top left corner.
      • Slide the pick toward the top right corner to separate the adhesive.
      • Leave the pick near the top right corner to prevent the adhesive from resealing.
      Ask FixBot
    13. Samsung Galaxy S24 Plus Battery Replacement, Separate the rear mic adhesive: step 14, image 1 of 2 Samsung Galaxy S24 Plus Battery Replacement, Separate the rear mic adhesive: step 14, image 2 of 2
      • There's a square of adhesive around the rear microphone, just above the flash.
      • Line up the tip of an opening pick with the flash.
      • Slide the opening pick under the top of the back cover until you feel it start to snag on the adhesive.
      • Keep sliding the pick toward the bottom of the phone while gently lifting the cover until the cover is free of the adhesive.
      Ask FixBot
    14. Samsung Galaxy S24 Plus Battery Replacement, Remove the back cover: step 15, image 1 of 2 Samsung Galaxy S24 Plus Battery Replacement, Remove the back cover: step 15, image 2 of 2
      • Grab and remove the back cover.
      • If the back cover is not lifting easily, use an opening pick to separate any adhesive that may have resealed.
      • During reassembly:
      • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
      • Retaining water resistance after the repair will depend on how well you reapply the back cover adhesive, but your device will lose its IP (Ingress Protection) rating.
      • Use tweezers or your fingers to remove all adhesive from the back cover and the phone. Use heat or isopropyl alcohol (90% or greater) and a coffee filter or lint-free cloth if you're having trouble removing the adhesive.
      • If you're using custom-cut adhesives, follow this guide.
      Ask FixBot
    1. Samsung Galaxy S24 Plus Battery Replacement, Disconnect the wireless charging coil: step 16, image 1 of 2 Samsung Galaxy S24 Plus Battery Replacement, Disconnect the wireless charging coil: step 16, image 2 of 2
      • Use a spudger to pry up and disconnect the wireless charging coil press connector from the motherboard.
      • There's an arrow printed on the board near each press connector that indicates the recommended prying location.
      • To reconnect press connectors, align the connector carefully over its socket and press down with your fingertip—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
      Ask FixBot
    2. Samsung Galaxy S24 Plus Battery Replacement, Remove the wireless charging coil and loudspeaker screws: step 17, image 1 of 3 Samsung Galaxy S24 Plus Battery Replacement, Remove the wireless charging coil and loudspeaker screws: step 17, image 2 of 3 Samsung Galaxy S24 Plus Battery Replacement, Remove the wireless charging coil and loudspeaker screws: step 17, image 3 of 3
      • Use a Phillips screwdriver to remove the thirteen 3.5 mm‑long screws securing the wireless charging coil and the loudspeaker:
      • Six screws securing the wireless charging coil
      • Seven screws securing the loudspeaker
      Ask FixBot
    3. Samsung Galaxy S24 Plus Battery Replacement, Remove the wireless charging coil and loudspeaker: step 18, image 1 of 2 Samsung Galaxy S24 Plus Battery Replacement, Remove the wireless charging coil and loudspeaker: step 18, image 2 of 2
      • Insert the point of a spudger in the notch at the top left corner of the loudspeaker, which is marked by an arrow.
      • Pry up to unclip the loudspeaker from the frame.
      Ask FixBot
    4. Samsung Galaxy S24 Plus Battery Replacement: step 19, image 1 of 3 Samsung Galaxy S24 Plus Battery Replacement: step 19, image 2 of 3 Samsung Galaxy S24 Plus Battery Replacement: step 19, image 3 of 3
      • Use your fingers to lift the loudspeaker away from the frame.
      • Remove the wireless charging coil and loudspeaker from the frame.
      • During reassembly, press around the edges of the loudspeaker to clip it to the frame before reinserting the screws.
      Ask FixBot
    1. Samsung Galaxy S24 Plus Battery Replacement, Disconnect the battery: step 20, image 1 of 2 Samsung Galaxy S24 Plus Battery Replacement, Disconnect the battery: step 20, image 2 of 2
      • Use a spudger to pry up and disconnect the battery press connector.
      Ask FixBot
    1. Samsung Galaxy S24 Plus Battery Replacement, Disconnect the interconnect cables: step 21, image 1 of 3 Samsung Galaxy S24 Plus Battery Replacement, Disconnect the interconnect cables: step 21, image 2 of 3 Samsung Galaxy S24 Plus Battery Replacement, Disconnect the interconnect cables: step 21, image 3 of 3
      • Use a spudger to pry up and disconnect both interconnect cable press connectors from the daughterboard.
      Ask FixBot
    2. Samsung Galaxy S24 Plus Battery Replacement: step 22, image 1 of 3 Samsung Galaxy S24 Plus Battery Replacement: step 22, image 2 of 3 Samsung Galaxy S24 Plus Battery Replacement: step 22, image 3 of 3
      • Use a spudger to pry up and disconnect both interconnect cable press connectors from the motherboard.
      Ask FixBot
    3. Samsung Galaxy S24 Plus Battery Replacement, Remove the interconnect cables: step 23, image 1 of 2 Samsung Galaxy S24 Plus Battery Replacement, Remove the interconnect cables: step 23, image 2 of 2
      • Grab and remove the interconnect cables from the phone.
      Ask FixBot
    1. Samsung Galaxy S24 Plus Battery Replacement, Disconnect the display and antenna cables: step 24, image 1 of 3 Samsung Galaxy S24 Plus Battery Replacement, Disconnect the display and antenna cables: step 24, image 2 of 3 Samsung Galaxy S24 Plus Battery Replacement, Disconnect the display and antenna cables: step 24, image 3 of 3
      • Use a spudger to pry up and disconnect the display cable and lower antenna cable press connectors from the motherboard.
      Ask FixBot
    2. Samsung Galaxy S24 Plus Battery Replacement, Remove the display cable: step 25, image 1 of 3 Samsung Galaxy S24 Plus Battery Replacement, Remove the display cable: step 25, image 2 of 3 Samsung Galaxy S24 Plus Battery Replacement, Remove the display cable: step 25, image 3 of 3
      • Use a spudger to pry up and disconnect the display cable press connector near the bottom edge of the phone.
      • Remove the display cable.
      Ask FixBot
    3. Samsung Galaxy S24 Plus Battery Replacement, Move the cables: step 26, image 1 of 2 Samsung Galaxy S24 Plus Battery Replacement, Move the cables: step 26, image 2 of 2
      • Push the battery and antenna cables out of the way of the battery.
      Ask FixBot
    4. Samsung Galaxy S24 Plus Battery Replacement, Peel back the pull tab: step 27, image 1 of 2 Samsung Galaxy S24 Plus Battery Replacement, Peel back the pull tab: step 27, image 2 of 2
      • Be very careful not to bend, crease, or puncture the battery during the next few steps. A damaged battery can leak dangerous chemicals and catch fire.
      • Peel the battery pull tab away from the battery, towards the left edge of the phone.
      • If you're having trouble getting the pull tab up, use and opening pick or other thin plastic tool at a low angle to peel up a corner. Never use a metal tool on battery, and never press into the battery.
      Ask FixBot
    5. Samsung Galaxy S24 Plus Battery Replacement: step 28, image 1 of 2 Samsung Galaxy S24 Plus Battery Replacement: step 28, image 2 of 2
      • Separate the small, clear tabs above and below the blue part of the pull tab from the rest of the pull tab.
      • Bend these small tabs away from the battery to make sure they stay clear of the battery.
      • If these tabs aren't separated, you won't be able to lift the battery in the next step. You can tape these tabs to the side of the phone or the screen to keep them out of the way.
      Ask FixBot
    6. Samsung Galaxy S24 Plus Battery Replacement, Lift the battery: step 29, image 1 of 3 Samsung Galaxy S24 Plus Battery Replacement, Lift the battery: step 29, image 2 of 3 Samsung Galaxy S24 Plus Battery Replacement, Lift the battery: step 29, image 3 of 3
      • This battery is held by a piece of double-sided adhesive film that is doubled under the battery. When you lift the battery by the pull tab, the left edge will come up, but the right edge will not. You'll remove the remaining film and the battery in the next step.
      • With one hand firmly holding down the frame of the phone, use firm, steady force to lift the blue pull tab straight up until the battery separates from the bottom layer of adhesive film.
      • If you're having trouble, apply 1-2 drops of high‑concentration (90% or more) isopropyl alcohol to the left edge of the battery. Raise the left edge of the phone to let the alcohol flow under the battery and wait one minute for it to soften the adhesive.
      • Lay the battery over the right edge of your phone.
      • Be careful not to bend the battery on the right edge of the phone frame. You may need to peel up some of the bottom layer of adhesive film by pulling the battery up before laying it over the edge of the phone.
      Ask FixBot
    7. Samsung Galaxy S24 Plus Battery Replacement, Remove the battery: step 30, image 1 of 3 Samsung Galaxy S24 Plus Battery Replacement, Remove the battery: step 30, image 2 of 3 Samsung Galaxy S24 Plus Battery Replacement, Remove the battery: step 30, image 3 of 3
      • Peel up the remaining film from the frame.
      • Remove the battery.
      • If you used isopropyl alcohol, wait ten minutes before installing the new battery to allow the alcohol to completely evaporate.
      Ask FixBot
For optimal performance, calibrate your newly installed battery after reassembling your phone.
2 other people completed this guide.
Spencer Pennington
27,659 Reputation
125 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
62,132 Guides authored
1 Guide Comment
great guide....good work!!
Mind of Mason - Reply Share
Past 24 Hours: 23
Past 7 Days: 160
Past 30 Days: 650
All Time: 9,546
