Samsung Galaxy S24 Front Camera Replacement
    1. Samsung Galaxy S24 Front Camera Replacement, Prepare your phone for disassembly: step 1, image 1 of 2 Samsung Galaxy S24 Front Camera Replacement, Prepare your phone for disassembly: step 1, image 2 of 2
      • Let your phone's battery drain below 25% before starting this repair. A charged lithium-ion battery may catch fire if damaged.
      • Completely power off your phone and unplug all cables.
      Ask FixBot
    2. Samsung Galaxy S24 Front Camera Replacement, Heat the right edge: step 2, image 1 of 1
      • Heat an iOpener and apply it to the right edge of the back cover for two minutes.
      • You can use also use a hair dryer or heat gun to heat the right edge of the back glass until it's hot to the touch.
      • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
      Ask FixBot
    3. Samsung Galaxy S24 Front Camera Replacement, Insert an opening pick: step 3, image 1 of 3 Samsung Galaxy S24 Front Camera Replacement, Insert an opening pick: step 3, image 2 of 3 Samsung Galaxy S24 Front Camera Replacement, Insert an opening pick: step 3, image 3 of 3
      • Apply a suction handle to the back cover, as close to the center of the right edge as possible.
      • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
      • If you have trouble, apply more heat to further soften the adhesive.
      • Insert an opening pick into the gap.
      Ask FixBot
    4. Samsung Galaxy S24 Front Camera Replacement, Separate the right adhesive: step 4, image 1 of 3 Samsung Galaxy S24 Front Camera Replacement, Separate the right adhesive: step 4, image 2 of 3 Samsung Galaxy S24 Front Camera Replacement, Separate the right adhesive: step 4, image 3 of 3
      • Slide your opening pick along the right edge between the back cover and the frame to slice through the adhesive.
      • Leave your opening pick in the bottom right corner to keep the adhesive from resealing.
      Ask FixBot
    5. Samsung Galaxy S24 Front Camera Replacement, Heat the bottom edge: step 5, image 1 of 1
      • Reheat your iOpener and apply it to the bottom of the back cover for two minutes.
      Ask FixBot
    6. Samsung Galaxy S24 Front Camera Replacement, Separate the corner adhesive: step 6, image 1 of 2 Samsung Galaxy S24 Front Camera Replacement, Separate the corner adhesive: step 6, image 2 of 2
      • Rotate the opening pick around the bottom right corner to separate the adhesive.
      Ask FixBot
    7. Samsung Galaxy S24 Front Camera Replacement, Separate the bottom adhesive: step 7, image 1 of 2 Samsung Galaxy S24 Front Camera Replacement, Separate the bottom adhesive: step 7, image 2 of 2
      • Insert a second opening pick to the left of the first one and slide it along the bottom edge to slice through the adhesive.
      • Leave your opening pick in the bottom left edge to prevent the adhesive from resealing.
      Ask FixBot
    8. Samsung Galaxy S24 Front Camera Replacement, Heat the left edge: step 8, image 1 of 1
      • Reheat your iOpener and apply it to the left side of the back cover for two minutes.
      Ask FixBot
    9. Samsung Galaxy S24 Front Camera Replacement, Separate the corner adhesive: step 9, image 1 of 2 Samsung Galaxy S24 Front Camera Replacement, Separate the corner adhesive: step 9, image 2 of 2
      • Rotate the opening pick around the bottom left corner to separate the adhesive.
      Ask FixBot
    10. Samsung Galaxy S24 Front Camera Replacement, Separate the left adhesive: step 10, image 1 of 2 Samsung Galaxy S24 Front Camera Replacement, Separate the left adhesive: step 10, image 2 of 2
      • Insert a third opening pick above the last one and slide it along the left edge to slice through the adhesive.
      • Only insert your pick up to 4 mm deep to avoid damaging the rear cameras or flash.
      • Leave your opening pick in the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    11. Samsung Galaxy S24 Front Camera Replacement, Heat the top edge: step 11, image 1 of 1
      • Reheat your iOpener and apply it to the top of the back cover for two minutes.
      Ask FixBot
    12. Samsung Galaxy S24 Front Camera Replacement, Separate the corner adhesive: step 12, image 1 of 2 Samsung Galaxy S24 Front Camera Replacement, Separate the corner adhesive: step 12, image 2 of 2
      • Rotate the opening pick around the top left corner to separate the adhesive.
      Ask FixBot
    13. Samsung Galaxy S24 Front Camera Replacement, Separate the top adhesive: step 13, image 1 of 3 Samsung Galaxy S24 Front Camera Replacement, Separate the top adhesive: step 13, image 2 of 3 Samsung Galaxy S24 Front Camera Replacement, Separate the top adhesive: step 13, image 3 of 3
      • Insert a fourth opening pick in the top left corner at the same depth and slide it along the top edge and around the top right corner to slice through the adhesive.
      Ask FixBot
    14. Samsung Galaxy S24 Front Camera Replacement, Separate the flash adhesive: step 14, image 1 of 2 Samsung Galaxy S24 Front Camera Replacement, Separate the flash adhesive: step 14, image 2 of 2
      • Insert a fifth opening pick directly above the camera flash cutout.
      • Insert the opening pick under the top of the back cover until you feel it start to snag on the flash adhesive.
      • Insert the pick deeper into the phone until you feel the adhesive completely separate from the back cover.
      • Don't insert the pick any deeper than its center point to avoid damaging the rear cameras.
      Ask FixBot
    15. Samsung Galaxy S24 Front Camera Replacement, Remove the back cover: step 15, image 1 of 2 Samsung Galaxy S24 Front Camera Replacement, Remove the back cover: step 15, image 2 of 2
      • Pick up the back cover by its edges and remove it from the phone.
      • If your cover is still sticking to the frame, slide the tip of an opening pick around the perimeter until the cover completely separates.
      • During reassembly:
      • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
      • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat and isopropyl alcohol (90% or greater) if you're having trouble removing the adhesive.
      • If you're using custom-cut adhesives, follow this guide.
      • If you're using double-sided tape, follow this guide.
      Ask FixBot
    1. Samsung Galaxy S24 Front Camera Replacement, Disconnect the wireless charging coil: step 16, image 1 of 2 Samsung Galaxy S24 Front Camera Replacement, Disconnect the wireless charging coil: step 16, image 2 of 2
      • Use the point of your spudger to pry up and disconnect the wireless charging coil press connector from the motherboard.
      • To re-attach press connectors, align the connector carefully over its socket and press down with your fingertip—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
      Ask FixBot
    2. Samsung Galaxy S24 Front Camera Replacement, Remove the wireless charging coil and loudspeaker screws: step 17, image 1 of 3 Samsung Galaxy S24 Front Camera Replacement, Remove the wireless charging coil and loudspeaker screws: step 17, image 2 of 3 Samsung Galaxy S24 Front Camera Replacement, Remove the wireless charging coil and loudspeaker screws: step 17, image 3 of 3
      • Use a Phillips screwdriver to remove the thirteen 3.5 mm‑long screws securing the wireless charging coil and the loudspeaker:
      • Six screws securing the wireless charging coil
      • Seven screws securing the loudspeaker
      Ask FixBot
    3. Samsung Galaxy S24 Front Camera Replacement, Remove the wireless charging coil and loudspeaker: step 18, image 1 of 2 Samsung Galaxy S24 Front Camera Replacement, Remove the wireless charging coil and loudspeaker: step 18, image 2 of 2
      • Insert the point of a spudger in the notch located on the left edge of the loudspeaker assembly.
      • Pry up the loudspeaker to release its clips.
      Ask FixBot
    4. Samsung Galaxy S24 Front Camera Replacement: step 19, image 1 of 3 Samsung Galaxy S24 Front Camera Replacement: step 19, image 2 of 3 Samsung Galaxy S24 Front Camera Replacement: step 19, image 3 of 3
      • Use your fingernail or the flat end of a spudger to pry up the wireless charging coil and loudspeaker assembly away from the frame.
      • Remove the wireless charging coil and loudspeaker from your phone.
      • During reassembly, press around the edges of the loudspeaker to clip it to the frame before reinserting the screws.
      Ask FixBot
    1. Samsung Galaxy S24 Front Camera Replacement, Disconnect the battery: step 20, image 1 of 2 Samsung Galaxy S24 Front Camera Replacement, Disconnect the battery: step 20, image 2 of 2
      • Insert the flat end of a spudger under the battery cable press connector (located on the motherboard) and pry up to disconnect it.
      Ask FixBot
    1. Samsung Galaxy S24 Front Camera Replacement, Disconnect the earpiece speaker: step 21, image 1 of 2 Samsung Galaxy S24 Front Camera Replacement, Disconnect the earpiece speaker: step 21, image 2 of 2
      • Insert the tip of a spudger underneath the left side of the earpiece speaker connector and pry up to disconnect it.
      Ask FixBot
    2. Samsung Galaxy S24 Front Camera Replacement, Remove the earpiece speaker screws: step 22, image 1 of 2 Samsung Galaxy S24 Front Camera Replacement, Remove the earpiece speaker screws: step 22, image 2 of 2
      • Use a Phillips screwdriver to remove the five 3.5 mm‑long screws securing the earpiece speaker.
      Ask FixBot
    3. Samsung Galaxy S24 Front Camera Replacement, Remove the earpiece speaker: step 23, image 1 of 3 Samsung Galaxy S24 Front Camera Replacement, Remove the earpiece speaker: step 23, image 2 of 3 Samsung Galaxy S24 Front Camera Replacement, Remove the earpiece speaker: step 23, image 3 of 3
      • Insert the flat end of a spudger underneath the bottom of the earpiece speaker assembly and pry up to free it from the chassis.
      • Remove the earpiece speaker.
      Ask FixBot
    1. Samsung Galaxy S24 Front Camera Replacement, Disconnect the front camera: step 24, image 1 of 2 Samsung Galaxy S24 Front Camera Replacement, Disconnect the front camera: step 24, image 2 of 2
      • Use a spudger to pry up and disconnect the front camera press connector.
      Ask FixBot
    2. Samsung Galaxy S24 Front Camera Replacement, Heat the front camera: step 25, image 1 of 1
      • The adhesive securing the camera is very strong. Work slowly and apply more heat if the camera feels stuck. Avoid separating the circuit board from the camera housing, such as this.
      • Use a hair dryer or a heat gun to heat the front camera for 90 seconds.
      Ask FixBot
    3. Samsung Galaxy S24 Front Camera Replacement, Remove the front camera: step 26, image 1 of 3 Samsung Galaxy S24 Front Camera Replacement, Remove the front camera: step 26, image 2 of 3 Samsung Galaxy S24 Front Camera Replacement, Remove the front camera: step 26, image 3 of 3
      Tool used on this step:
      Tesa 61395 Tape
      $2.95
      Buy
      • Use the flat end of a spudger to pry the front camera from its recess in the frame.
      • The adhesive separates easiest with consistent force applied.
      • If the camera doesn't loosen, use the point of your spudger to scrape away the epoxy surrounding the camera.
      • During reassembly, you will need replacement adhesive to secure the replacement part to the frame. If your part does not include new adhesive, use thin, double-sided tape instead.
      Ask FixBot
Compare your new replacement part to the original part—be sure to transfer remaining components and remove adhesive backings from the new part before installing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Samsung Galaxy S24 Answers Community for troubleshooting help.
Nick Schultz
67,175 Reputation
353 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,713 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 35
Past 30 Days: 153
All Time: 1,609
