Samsung Galaxy S24 Battery Replacement
      • Step 1 — Heat the Back Cover For 1–2 minutes, use a heat gun or an iOpener on the back cover in order to melt the glue. If necessary, reheat to keep the glue hot.
      Ask FixBot
      • Step 2 — Separate the Back Cover A suction handle should be placed at the bottom edge of the back cover and pulled up to make a small space. A plastic opener should be inserted into this space. The tool should be moved around the sides to cut the glue. Keep doing this until the back cover is off.
      Ask FixBot
      • Step 3 — Disconnect the Battery A spudger should be used to detach the battery connector straight up from its plug. Step 4 — Remove the Wireless Charging Coil Screws Take out the screws that hold the coil: Red ♦ 8× Phillips 3.5 mm screws
      Ask FixBot
      • Step 5 — Remove the Wireless Charging Coil The coil should be lifted straight up and put aside. Step 6 — Disconnect the Battery Ribbon Cable Lift the black locking bar on the ribbon connector. Pull the ribbon cable straight out.
      Ask FixBot
      • Step 7 — Remove the Battery Heat the display side of the phone for 1 minute to loosen the adhesive under the battery. Insert a plastic card under the right edge of the battery. Gently slide the card downward to release the adhesive. Repeat from the left side until the battery is free. ⚠️ Do not puncture or bend the battery.
      Ask FixBot
      • Step 8 — Install the New Battery Remove the old adhesive and apply new adhesive strips. Place the new battery into position and press firmly. Reconnect the ribbon cable and close the locking bar. Step 9 — Reinstall the Wireless Charging Coil Place the coil back into position. Reinstall all eight screws.
      Ask FixBot
      • Step 10 — Reassemble the Phone Reconnect the battery connector. Apply new adhesive to the back cover. Press the back cover firmly until it fully seals around the edges.
      Ask FixBot
Imran Tanvir
172 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 72
Past 30 Days: 228
All Time: 859
